E-brake replacement
Old Oct 20, 2003 | 03:29 PM
GeoBau's Avatar
Cactus Hugging Admin
E-brake replacement
Don't ever let anyone else drive your car. Period.
My mother took out my old SHO and put on the E-brake when she parked it. She then drove it again for about 30-45 min and had forgotten it was on. I know this is a different car, but I figured this crowd would be the most knowledgeable-- what am I looking at? She said she tried to engage it later, but it wasn't stopping the car from rolling while in N. Thanks,
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
Old Oct 20, 2003 | 03:56 PM
AntRock's Avatar
Re: E-brake replacement
it sounds like you will be needing new rear brakes, pads and disks. the e brake is basically a cable that is attached to your rear callipers that engages them, so i am sure your pads are gone and your rotors are warped, if you do it yourself it could be anywhere from $100-200 depending on what rotors you get, i would sugest going after market not oem.
Old Oct 20, 2003 | 05:01 PM
Rumble's Avatar
I agree to go check out the brakes and if they do not need replacing (hopefully) then the e-brake and rears just need to be tightened.
It's still a G thang!!
Old Oct 22, 2003 | 12:39 AM
rstark's Avatar
Sorry, thought you were talking about a G35, this should be posted in the other cars forum.
Old Oct 22, 2003 | 08:21 AM
AntRock's Avatar
are you sure about that on a ford taurus.
Old Oct 22, 2003 | 02:52 PM
davey2003's Avatar
Yea you have to check the way your car uses the e-brake. Some use a drum style where the e-brake has a seperate shoe for use as a brake and then there are the e-brakes that use the regular brake pads. The cable just manually pulls the pads onto the rotor instead of hydraulic pressure. It being a ford I'm assuming that it's using the drum style where it has the shoe inside of the rotor hub. I think that's how you would describe.
Old Oct 23, 2003 | 05:42 PM
GeoBau's Avatar
I'll check it out. There appears to be excess dust on the front left wheel, and my mom said the front was "smoking" when she brought it in from her e-brake cruise. I've hidden the keys to her FX to punish her.
G
11bEMT
May 27, 2022 03:13 PM
ara777
Aug 15, 2018 04:11 AM
snic09
Nov 8, 2017 01:46 PM
miata007
Aug 17, 2015 04:36 PM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
