Will going from 17" to 16" affect speedo?
Old Oct 23, 2003 | 07:50 PM
noel48's Avatar
My snows arrived and I just thought of this.Anyone know?
2003.5 G35
2003 350Z
2003 Murano SL
Old Oct 23, 2003 | 08:00 PM
ryoken's Avatar
Re: Will going from 17" to 16" affect speedo?
It depends on the tire size. What size snow tires did you order? Do you have a coupe or a sedan? It's the outer diameter of the tire that needs to be the same as your stock tires to keep the speedometer/odometer in sync.
Tire Size Calculator
Old Oct 24, 2003 | 05:15 AM
noel48's Avatar
I have a sedan.The snows are 205/65/ 16.
2003.5 G35
2003 350Z
2003 Murano SL
Old Oct 24, 2003 | 11:12 AM
ryoken's Avatar
That is actually the stock size for the '03 cloth sedan that comes with 16" wheels, and is very close to the 17" tire diameter. It's roughly 0.7% larger, or when your speedometer reads 60, you'll actually be going 60.4. Negligible difference.
Old Oct 24, 2003 | 06:22 PM
noel48's Avatar
Thanks Ryoken.
2003.5 G35
2003 350Z
2003 Murano SL
Old Oct 26, 2003 | 12:59 AM
EL_PAALO's Avatar
Here's a handy calculator for determining that and other wheel/tire info.
http://www.discounttire.com/dtc/broc...o/tireMath.jsp
http://www.wheelspecs.com
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
HeyAsianKid
Intake & Exhaust
Oct 7, 2015 01:55 PM
AT23
Sep 15, 2015 07:44 PM
