Anyone run 235/30 and 265/30 for their factory 19's am I ok doing this?
Old Oct 18, 2006 | 01:12 PM
bigedx2002's Avatar
Anyone run 235/35 and 265/30 for their factory 19's am I ok doing this?
Can get a real good price on these, just curious if anyone has tried it before. thank you for your help.
Old Oct 18, 2006 | 01:24 PM
_jb's Avatar
_jb
Photographer
Tire diameter on the fronts is inch and a half smaller... Use this tire calculation tool...
http://www.miata.net/garage/tirecalc.html
Old Oct 18, 2006 | 06:15 PM
bigedx2002's Avatar
im sorry i meant 235/35 and 265/30 the front diameter is .5 smaller both tires will be within .2 inches of one another. I know i will have less sidewall but will it still be okay?
Old Oct 18, 2006 | 07:05 PM
bigedx2002's Avatar
After going to look at a 265/30 im afraid its not nearly enough sidewall... im either going to go with 235/35 and 245/35 or would going 245/35 all around work? anyone try it?
Old Oct 18, 2006 | 07:44 PM
lowrider's Avatar
With the factory 19s. The fronts are 8" wide and the rears are 8.5". You could put 245/35/19 on the front and 265/35/19 on the rear. You would maintain the stagger. And the 265s should work with the 8.5" rear. 245/35 all the way around would kill the stagger and interfere with the electronics (VDC).
Lou
Old Oct 18, 2006 | 07:52 PM
bigedx2002's Avatar
thank you for your help, i think im going to go with 235/35 and 245/35 unless im going to run into terrible problems
Old Oct 19, 2006 | 04:55 AM
j-velocity's Avatar
I came accross a good deal on a set of 235R19F and 265/30R19R.
It works just good.
The VDC seems work ok even the tires are ~1" smaller in diameter.
235/35 and 265/30 are in the same size in terms of diameter.
Old Oct 19, 2006 | 06:17 AM
bigedx2002's Avatar
can you post some pictures please?
Old Oct 19, 2006 | 01:08 PM
bigedx2002's Avatar
Just wanted to thank thoses who helped with this decision, someone in another thread said its a 40k car, why cheap out on the tires, they are absolutly right. I ended up going with
Falken FK-452
245/35ZR19 f
245/40ZR19 r
Old Oct 19, 2006 | 01:34 PM
lowrider's Avatar
That someone was me. Glad your happy, and have tires with the proper stagger that fit the wheels. Good Luck.
Lou
Old Oct 20, 2006 | 07:22 PM
madscientist's Avatar
Lou
that was you.
anyway, i ended up going with Toyo Proxes T1R - 245/35/19 in the front and 275/35/19. Ordered them yesterday.
NJ6MT
Sep 10, 2015 08:40 AM
n2fooz
Sep 4, 2015 07:46 PM
G35CO
Sep 4, 2015 09:27 AM
