rear camber???
rear camber???
I was just wandering why is my rear tire going bald in the back and only the inner side? How can you change the setting or what do I have to install to correct this problem?
Some one Please help...
Re: rear camber???
My car came from the factory with -2.33 degrees of negative camber, which is out of spec. It sounds as though your car has the same issue. As I prefer a drag race set-up as opposed to a cornering set-up, I had the car aligned and the negative camber reduced to -.50. This adjustment was made using the factory adjusters that are on the car. For adjustments above and beyond that, aftermarket camber rods or camber plates are required.
ZEX wet kit 140 WHP
ZEX remote opener, bottle heater
Denso iridium 2 steps
Z tube, Amsoil filter
JIC-Magic traction rods
BFG Drag Radials 265/40/18
12.85 @ 108.5
ZEX wet kit 140 WHP
12.85 @ 108.5
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
