Anyone thought of this idea?
Old Nov 4, 2003 | 12:50 PM
Renesis's Avatar
In the coupe, the wheels is 225 in front 245 in back right?
This setting produces a minor understeer. Have anybody thought about switching them around?? I saw many aftermarket tuners in Japan like to use wider tires in front to reduce understeer or even create a slight OVERSTEER for drifitng. Anyone?
Old Nov 4, 2003 | 12:53 PM
G35Gnome's Avatar
Re: Anyone thought of this idea?
Even if you were to do that you cant with the stock tires/rims, the rear ones have a larger diameter.
Crawford Plenum / Z tube + Stillen Hi-Flow / Borla Dual Exhaust / Stillen Xdrilled+Stotted Rotors
Best 1/4 mile 14.371 @ 100.29, 60ft 2.347
Old Nov 4, 2003 | 12:55 PM
Renesis's Avatar
Oops, I just checked and I found out that I miss lead people. The sizes are the other way around. Nevermind!
Old Nov 6, 2003 | 04:07 AM
DallyCurtis's Avatar
what do you mean .. the rims have a larger diameter in the back ... ??
I thought they were both 8 inch rims?
Old Nov 6, 2003 | 02:22 PM
lowrider's Avatar
Stock 18s are 8" wide all the way around. The rear wheels wont mount in the front however, because of a protruding pin on the base of the front disks that the front wheel accomodates. The 17" wheels are 7.5" front and 8" rear.
Lou
BTW, you don't want to do a front/rear reverse anyway. You'd upset the stagger big time, and cause evil handling and VDC operation.
Old Nov 6, 2003 | 04:29 PM
OvaYahead's Avatar
rear rims will fit on the front. Just remove that screw on the front rotor. I forget what size socket to use 10 or 12, but it comes out very easy. It's only about 2 threads deep.
I had to remove those bolts when I put my 20's on.
BS G35C 6spd navi/aero/prem
Old Nov 6, 2003 | 10:09 PM
lowrider's Avatar
I never said that you couldn't remove it, all I said was that it was there and what the purpose was: To prevent people from doing something stupid. BTW, My Nismos work the same way. Fronts will mount due to the spacing, rears wont mount in front with the pin.
Lou
chinee
Jun 10, 2024 07:48 PM
Spartan268
Aug 20, 2015 09:14 PM
jjohns2711
Aug 5, 2015 08:58 AM
