Advise please
Old Jan 23, 2003 | 03:06 PM
Marcel's Avatar
Advise please
I plan on purchasing
Wheels - Volk GT-c 19x8.5 front
19x9.5rear
tires - Potenza SO3 245/35/19
245/35/19
If i make this upgrade to my 6mt coupe will i have a problem fitting my brembos? Does anyone have any idea of how much gap there will be between the tires and wheel well? Also by making this trade will i pretty much be eliminating any additional suspension work? I would love for my car to drive better with some suspension kit or spring kit of some kind. But typically they lower your car, what would happen to my car in this case? Is it not possible? Should i just upgrade my suspension then wait and do my wheels/tires later?
Thanks
Marcel
Old Jan 23, 2003 | 05:11 PM
rxkeven's Avatar
Re: Advise please
I am a little confused why you are getting 19x9.5 rear without getting a wider tire. You are not going to be able to rotate anyway w/o remounting & balancing. so what is the advantage.
If you want 9.5 in the rear might as well go 265 or 275... or just go 19x8.5 all the way around, some guys have done that, but I prefer the wider stance in the back.
G35 Coupe / Premium / Nav
Ivory Pearl / Willow Leather
SSR GT3 19"s w/ Bridgestone SO-3
Old Jan 23, 2003 | 05:31 PM
Gthang_KC's Avatar
Re: Advise please
Marcel,
If you are planning on upgrading your wheels, you will need to pay particular attention to the offset and wheel design that will allow caliper clearance. I would suggest getting a set that have been tested for 6MT. I am not to sure about Volks.
2003 G35c Diamond Graphite/Premium/Performance Package
Old Jan 23, 2003 | 07:21 PM
pestilence's Avatar
Re: Advise please
I dont konw about your clearance questoin but tires... Yeah... potenza S0-3's....... nice...
..pestilence..
Old Jan 24, 2003 | 12:04 PM
Marcel's Avatar
Re: Advise please
Thanks for the input guys. I had initially thought about goign with a wider rear tire but wasnt too sure on how wide so i had decided equal all around. But with your input I will definately go with a much wider tires. how about this?
Volk GTC 19x9 front
19x10 rear
Potenza SO3'S 245 or 255/35/19 front
285 or larger/35/19 rear
Thanks
Marcel
Old Jan 24, 2003 | 03:34 PM
damen's Avatar
Re: Advise please
you may not want to go larger the 285 in the back. it may balloon out.
Old Jan 25, 2003 | 02:35 PM
Marcel's Avatar
Re: Advise please
What about max on front?
Marcel
esotericrider
Feb 14, 2022 07:19 AM
Dmill86
Sep 6, 2015 08:14 PM
bjo16
Aug 4, 2015 09:52 AM
CJay
Aug 1, 2015 03:57 AM
