235/45/18 in the Front on OEM 18"
Old Jan 6, 2007 | 01:05 PM
Marshall2K's Avatar
Does anyone know if there would be any rubbing issues with 235/45/18 in the front on OEM 18 wheels.
I know stock is 225/45/18 and the 245/45/18 would rub in the front. I don'y want to run a thinner 40 tire up there, but i want some width.
Old Jan 6, 2007 | 01:32 PM
light's Avatar
no rub man. ur fine
Old Jan 6, 2007 | 02:00 PM
avs007's Avatar
What's wrong with 245/40-18? That will give you width, while maintaining almost the same rolling size. It's not like 245/40-18 are rubber bands or anything.
Old Jan 8, 2007 | 11:03 AM
Mountian Pirate's Avatar
Big time...That's my combo, 245/40 front 255/45 rear 18's.. no problems what so ever.
Old Jan 10, 2007 | 10:30 PM
Madelinot's Avatar
No problem at all. I'm running 245/40 at the front and 275/40 at the rear on stock rims. Great combo, no rubbing. They bulge a little at the back, but nothing that I would worry about. They look good too and the diameter is within 1-2% of stock tires.
Old Jan 16, 2007 | 05:50 PM
mrwhtfks's Avatar
hey guys would there be any problems with running 225/40/18 front and 245/40/18 on the OEM 18" wheels? I know the stocks are xxx/45/18 but what issues could I have with that?
Old Jan 17, 2007 | 02:50 PM
HMM...would have to goto tiirerack to check diameters...you need to keep the same relative diameter ratio front to rear (pretty close) as stock.
Possible VDC issues I would imagine if the tire diameters are not kept within reason in regards to stock.
Xfactor
Dec 1, 2019 12:52 PM
Tukeeg35
Sep 27, 2015 12:16 AM
stay_tuned
Jul 21, 2015 07:09 PM
