Wheel Questions?
Old Jan 26, 2007 | 11:28 AM
Dubfound's Avatar
Wheel Questions?
Hello! What/s up wheel gurus?! I have an opportunity to pick up a sweet set of staggered wheels! Here are the specs:
-19” 8.5” in the front 2”lip and 10” in the rear 3”lip.
-The front is 35mm and rear is 20mm offset.
1 Will these clear my Brembros? 2 What tire size? 3 Will they sit flush with my fenders?
Thanks a lot!!!
Old Jan 26, 2007 | 05:27 PM
Calvin's Avatar
Overglorified Altima
front offsets are crap especially when considering it's an 8.5" wheel
jmho
Old Jan 26, 2007 | 06:02 PM
kenchan's Avatar
dubfound- really depends on the shape of the spokes...
you can run 3mm spacers for extra clearance, or just get
some Kics 15mm spacers that comes with new studs. i
use those. they are great. make sure your aftermarket
wheel has enough space between the lugs as the stock
studs will protrude about 12mm.
Old Jan 26, 2007 | 06:33 PM
Dubfound's Avatar
They are Iforged wheels.. Not sure if that matters? Thanks for the info though! I guess we will have to see if they fit....................
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
