What size for New Tires?
Old Feb 2, 2007 | 02:28 PM
ron4row2's Avatar
I'm purchasing new tires for my 2004 G sedan. I was thinking of going with 225/50/17 instead of the stock 215/55/17. Any thoughts on why I shouldn't do this?
Old Feb 2, 2007 | 02:48 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
many people have gone that route, or you can go with a 235/45/17 whatever floats your boat.
-GP-
Old Feb 2, 2007 | 02:57 PM
gramdacious's Avatar
^+1 on the 235/45/17s. That's what I just put on and the handling is night and day.
Old Feb 2, 2007 | 03:04 PM
GGRJR's Avatar
If you go with 235-50-17, the overall diameter will be nearly the same. That way your speedometer will be, fairly, accurate.
Old Feb 2, 2007 | 04:15 PM
ttrank's Avatar
Grocery getter
^+1
Keep it as close as you can.
Old Feb 2, 2007 | 04:20 PM
joedaddy1's Avatar
rn't our rims only 7"'s wide?
Old Feb 2, 2007 | 05:34 PM
kailep's Avatar
OEM rims, 7", will fit up to 235/50/17 w/o problem according to Tire Rack.
even my wife CRV 6.5" rims have 225 on there.
Old Feb 2, 2007 | 05:44 PM
G35Luv's Avatar
Just curious if any of you guys notice a MPG drop with the wider tires than stock?
Old Feb 2, 2007 | 08:31 PM
GGRJR's Avatar
I haven't put larger tires on the G (yet), but basic physics would indicate a slight decrease do to rolling resistance. I do know goning from a 245 to 265 on my F150 caused about a 10 percent decrease, in mileage but I also went taller (speedometer adjusted).
Old Feb 4, 2007 | 02:22 PM
dbarnes's Avatar
I went with Goodyear Eagle F1-GSD3's in a 235/50/17 size - fit great, no sidewall "bulge", and speedo fairly accurate (49 MPH indicated vs. 50 MPH Radar).
Any other size on stock rim will cause a greater variance in speedo (and false actual MPG figure, since that's an inaccurate read as well).
Negligible (1 mpg or less avg ?) effect from increased rolling resistance (width), more than overcome by euphoria of great handling with these tires!
My $0.02
Old Feb 4, 2007 | 02:32 PM
I'd trade 2-3 MPH off of my speedo for 45 series tires personally. Anyways I look at that 2-3 MPH as a "buffer" so I'm always going a tad slower than my speedo says.
Old Feb 5, 2007 | 11:19 AM
forourspam's Avatar
There you go, homie!
http://www.tirerack.com/tires/Compar...t=All&x=76&y=5
Old Feb 6, 2007 | 08:30 AM
ron4row2's Avatar
What is the real difference between the 50 and 45 series for the 235/17? will the 45 series rub on the front? Does anyone have any pics to see the difference?
Old Feb 6, 2007 | 08:49 AM
GGRJR's Avatar
The only difference between the 45 vs 50 series is the ht of the side wall. This of course will have a slight effect on teh thread width, bu not really on teh over all width. If you go to teh tire rack website, they have a good expalnation on tire sizing.
Old Feb 6, 2007 | 02:56 PM
ron4row2's Avatar
Is there a benefit with going with the 45 over the 50?
