My car wobbles, even after getting new tires blanced and aligned..
Old Feb 7, 2007 | 01:26 PM
Guapo's Avatar
Help guys, I'm not sure what's going on with my car. Several weeks ago, I got a flat tire and I replaced all four tires with 19 inch Michelin Pilot Sport on my stock rims. The tires were balanced and then I had the car aligned at Firestone. I've noticed that my car starts to shimmy when I'm driving on the freeway. My car never did this with my old tires and I'm not sure if this is normal. I was thinking maybe the freeway is causing this shimmy effect or maybe my rim is bent, but the rim looks perfectly fine and everything was balanced and aligned. Anyone have any advice as to what I should do or have checked out on my car?
Old Feb 7, 2007 | 07:47 PM
Jason@Riverside's Avatar
New tires do take some time to break in... There are kind of slick at first from the molds when being made...
How many miles have you put on them since they were brand new?
Old Feb 7, 2007 | 11:00 PM
kenchan's Avatar
if sedan put your rear tires on the front and see if that vibration continues.
if no, your front tires are out of balance.
if on the coupe.... kinda out of luck. take it back and get it re-balanced
on a hunter machine.
Old Feb 8, 2007 | 12:33 AM
I missed the part you said when it starts to Shimmy... Make sure the lugs are all torqued properly!!!!
Old Feb 8, 2007 | 08:42 AM
kenchan's Avatar
^ +1 torque up to 88lbs/ft and see.
Old Feb 8, 2007 | 10:08 AM
Texasscout's Avatar
Is it cold? They may be "flat spoting".
Old Feb 9, 2007 | 06:48 AM
Ferrarimanic360's Avatar
ive been having this problem too, im gonna take it to get an alignment and see what they say, i think you should do the same
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
wojowojo16
Jul 27, 2015 09:57 AM
itschuckster
Jul 25, 2015 08:07 AM
realtalk21
Jul 20, 2015 09:07 AM
mushu
Jul 15, 2015 03:55 PM
