How does offset work?
Old Nov 29, 2003 | 01:08 AM
gdupg35's Avatar
I curious what the difference is compared to stock on a +45 versus a +38 offset wheel.
Old Nov 29, 2003 | 04:25 AM
Msedanman's Avatar
O.F. Administrator
Re: How does offset work?
The offset refers to the distance from the centerline of the wheel.
The difference between the stock Sedan 17" offset of 45mm and 38mm is 7mm (per side). So if you use the 38mm offset instead of the 45mm you will widen the tread (the distance between wheels) by 14mm. (about .55").
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 29, 2003 | 10:24 AM
lowrider's Avatar
Go Here:
http://discounttiredirect.com/direct...eelOffsets.jsp
Lou
Old Nov 30, 2003 | 07:40 AM
gdupg35's Avatar
Let me see if I have this straight. A wheel with a .38 would sit farther IN than a stock wheel. I'm trying to determine what to do about my rubbing issue on my sedan with 20's. I'm sure there were a few sedans lowered on here that do not rub in front but can't seem to find them anymore.
(Please don't offer up suggestions like "put the stock springs on" or you can shizzle my nizzle.)
Old Dec 1, 2003 | 11:29 AM
ryoken's Avatar
First, it's 38mm, not .38 anything.
Second, no, a smaller offset would push the wheel out, away from the center of the car.
Old Dec 1, 2003 | 05:55 PM
Gordgee's Avatar
Administrator
That .38 could be that gun strapped to the tire![img]/w3timages/icons/laugh.gif[/img]
<font color=green>GG</font color=green>
Old Dec 2, 2003 | 10:43 AM
dholly's Avatar
Sharpen your pencil, turn on your calculator, use this backspace to offset conversion chart:
To convert from inches to mm multiply by 25.4
To convert from mm to inches divide by 25.4
That and more found here: http://www.rsracing.com/tech-wheel.html
___________________________________
2004 | 6MTs | Diamond Graphite/Graphite
Old Dec 2, 2003 | 10:14 PM
don1's Avatar
Any advantage or harm caused by using a different offset to widen the track of the car, say 0.5" to 1.0" on my sedan, using the stock 17's ? Would this mess with the stability control system?
Old Dec 4, 2003 | 01:06 AM
Gordgee's Avatar
Administrator
It would probably cause a bit more stress on the suspension components and some problems in long-term wear.
arora_g35
Apr 16, 2026 02:52 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
attarday
Jul 15, 2015 04:03 PM
