Nismo 57F 18x8.5 for Altima / Maxima confirmed to fit on G35 sedan
Old Feb 9, 2007 | 10:12 PM
gruppe-s's Avatar
Former Sponsor
Although designed for the Altima / Maxima, these wheels are an excellent fit for the G35 sedan (245/40/18 tire ok). With the Nissan 66mm center bore you won't have to run hub rings. Unfortunately it's not recommended for the coupe though (or else I'd have them on my 6spd... )
$999/set right now
Cheers,
Gary
Gruppe-S
Old Feb 10, 2007 | 03:15 AM
Calvin's Avatar
Overglorified Altima
wow what is that sedan lowered on?
Old Feb 10, 2007 | 10:24 AM
GGRJR's Avatar
Which offset are these?
Old Feb 10, 2007 | 05:28 PM
gruppe-s's Avatar
Former Sponsor
As I recall (sorry my memory is no good) the Sedan is on coilovers - it's pretty low. The offset of the wheels are a +45. It's a bit on the higher side for the Sedan (optimal being +39), but it works. You can always run a +5mm spacer if you so wish.
The deal is pretty special because we did a $100K+ deal to purchase all of Nismo 57F overstock. Normally cold-forged wheels from any manufacturer (BBS, OZ, Rays) will go for over $2000/set in 18".
Cheers,
Gary
Gruppe-S
Old Feb 10, 2007 | 07:01 PM
Blackbird V35's Avatar
mayeb its the angle but the tires look really really small
Old Feb 12, 2007 | 07:32 PM
gruppe-s's Avatar
Former Sponsor
Yeah, it's probably the angle, it's a 245/40/18. The 245/40/18 comes pretty close to the shock body in the front (so I wouldn't go any wider), you can go wider in the rear though (255/40/18 is ok).
It's not coupe tire sizes, but it's pretty well suited to hold 300HP.
Cheers,
Gary
Gruppe-S
Old Feb 13, 2007 | 09:45 AM
myG35ZX's Avatar
What about BBK clearance?
Old Feb 20, 2007 | 05:46 PM
gruppe-s's Avatar
Former Sponsor
The +45 I don't think will clear Brembo BBK on the sedan. The stoptechs maybe, but we have not tested them to do so - so I would say unfortunately they probably won't clear.
Thanks,
Gary
Gruppe-S
Old Feb 20, 2007 | 05:53 PM
da mayor's Avatar
those nismo wheels are ligth
Old Feb 22, 2007 | 09:27 PM
gruppe-s's Avatar
Former Sponsor
Yup they're cold forged
Got these bad boys on sale for $999/set right now in teh vendor section. Thanks!
Gary
gary@gruppe-s.com
Old Mar 9, 2007 | 03:18 AM
dahkyne's Avatar
Cheers,
Gary
Gruppe-S
I have a sedan and was wondering...
Can you run 245/45 and not rub?
What about 225/45 in front and 245/45 rear?
will 225 in front stretch a lot on an 8.5" width?
Or is it safer just to do 235/45 on all four corners?
Old Mar 12, 2007 | 10:21 PM
gruppe-s's Avatar
Former Sponsor
Hi,
1. We tested 245/40, not 245/45, can't confirm 245/45, but I think it should be fine.
2. I would do 235/45 all the way arond - that would allow you to rotate tires also.
225/45 on an 8.5 is not too bad, I ran that on my E36 BMW for a long time. 8.5" = 215mm, so even when you add in the lips of the wheel, 225 tire is pretty reasonable.
Cheers,
Gary
Gruppe-S
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
LoSt180
Jul 15, 2015 08:31 AM
