19"SSR GT2 offset question....
Old Feb 10, 2007 | 05:26 AM
turb0mister2's Avatar
im thinking about picking up a set upf ssr gt2's for my 6spd coupe, how doe theres sizes sound?
19x9 +31 with a 245/35/19 or a 255/35/19
19x10.5 +43 rear with a 285/35/19 or a 295/35/19
the car is stock, with stock brembos, but i might lower it a little with some tein CS's.
what kinda of problems will i run into with this tire/wheel combo?
tire sizes is open for change, but offsets are pretty set, let me know, thanks.
johnny
Old Feb 10, 2007 | 11:46 AM
SilverII's Avatar
offset way too high...wont work
Old Feb 10, 2007 | 11:49 AM
o0MrJujuBee0o's Avatar
What do you mean it wont work? It won't work because it will not fit or because the set up won't be aggressive? Let me know. Thanks in advanced.
Old Feb 10, 2007 | 12:53 PM
redlude97's Avatar
a 10.5 +43 wheel will extend an extra 35mm inside, which may not clear the suspension, and extend an extra 15mm out. My guess is a 20/25mm spacer should be used to gain extra clearance in the rear and a 10mm spacer in the front
Old Feb 10, 2007 | 01:44 PM
these offsets were given to me from tirerack for a 350z, is there a differences between the two cars needed offsets? usually tirerack wont sell you a set of wheels unless the wheels will fit the car right?
johnny
Old Feb 10, 2007 | 02:24 PM
redlude97's Avatar
johnny
They'll fit, but tirerack uses sizes that are usually very conservative, to most of us it will look funny, but the only person that matters is yourself
Old Feb 10, 2007 | 03:20 PM
Calvin's Avatar
Overglorified Altima
as redlude said, most (if not all) of us will think it looks waaay too tucked in with those offsets.
z and g offsets are the same.
Old Feb 10, 2007 | 09:59 PM
kenchan's Avatar
my GT3's are +37 front and +41 rear and they "fit" as is... but the
front clearance to brembo's were too close for my taste (2-3mm tops).
im running 15mm Kics spacers so +22 front and +26mm rear... imho,
a perfect fit.
Old Feb 10, 2007 | 11:42 PM
SuperShick's Avatar
kenchan, do u have a picture of your SSR GT3s? those are one of the baddest wheels....i love the thing 5-spoke design =)
Old Feb 11, 2007 | 05:44 PM
turb0mister2,
Check out my post on wheel offsets: https://g35driver.com/forums/wheels-tires/139394-g35-coupe-oe-wheel-fitment-offset.html
Old Feb 12, 2007 | 12:47 AM
kenchan's Avatar
thanks. couple of older picts. picts dont do these wheels justice.
ill be taking more this spring with the rear spoiler i just got. too cold
to install it still.
Old Feb 12, 2007 | 01:00 AM
SuperShick's Avatar
the rear lip doesn't look too huge. are there different versions of it with bigger lip?
Old Feb 12, 2007 | 01:07 AM
Triple8Sol's Avatar
Those offsets will look HORRIBLE. With some big spacers, look they'll be fine. Go w/the 255/285 combo, you'll be fine unless you have an extremely low drop. Oh, and if you have Brembos, those wheels might not clear...
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
Usman Ali
Oct 4, 2015 08:23 PM
TurTLe*
Sep 29, 2015 01:43 PM
