Tire size
Old Feb 11, 2007 | 09:47 PM
GISMO35's Avatar
Tire size
Looking for some new tires for my 03 coupe. Would changing from OEM 225/45/18, 245/45/18 to 225/45/18 and 245/40/18 pose a problem? Just changing the rear profile.
Old Feb 11, 2007 | 09:48 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
It wouldnt cause a problem, but why would you want to go with a lower profile in the rear?
-GP-
Old Feb 11, 2007 | 10:36 PM
GISMO35's Avatar
The tires I'm looking at do not come in 45, Kuhmo SPT's.
Old Mar 7, 2007 | 02:04 PM
mrmcderm's Avatar
I would think 245/40s in the rear *would* cause problems. Specifically with the VDC. Dropping the profile like that is going to reduce the overall diameter by 3.75%, making the rears spin faster by that amount. I don't know how sensitive the VDC is, but if its differential threshold is under 3% you may have to keep the VDC off with that setup.
I'm shopping around for tires on the OEM 18" rims as well, and one thing I want to maintain is the stagger between front and rear to avoid having the VDC go nuts.
I want wider rubber front and rear, but I'm having trouble finding the tire models I want in the sizes that stay as close as possible to the 2.656% rotational speed differential between front and rear.
The best options I've come up with are 235/45ff 255/45rr or 245/40ff 245/45rr but sizes are hard to find in the first combo, and I'm concerned about the VDC in the second.
I have been unable to find details on the sensitivity threshold of the VDC. I would think selecting a size package that spins the fronts slower than stock would be ok, but who knows?
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
