Best tires for OEM 19s
Old Feb 23, 2007 | 11:25 AM
Slick 6MT's Avatar
Originally Posted by arizonag35coupe
I'll be throwing on a set of 245/35 in the front and 265/35 in the rear...I'll post my impressions when I get them on.
What are you putting on? Toyo?
Old Feb 23, 2007 | 11:28 AM
arizonag35coupe's Avatar
Continental ContiSportContact 3's....looked like a pretty solid tire and at $1090 installed its really not much more expensive than if I did OEM replacements.
Old Feb 23, 2007 | 12:42 PM
abcdang's Avatar
what about using 245/40/19's all the way around? i think that gives you a few more tire choices.
Old Feb 23, 2007 | 01:02 PM
bpr262's Avatar
I am no pro, but I think I remember reading somewhere that going with same size all around will screw up the VDC. Makes sense since VDC was programmed on a staggered set up.
I'm sure someone will correct me if I am wrong though.
With respects actual brands, I think Michelin PS2 are highest rated, but also most expensive. Toyo T1R get great reviews, not to mention easier on the wallet.
I'm no expert on these matters, but I believe that will create problems with your VDC or Tire Pressure Sensor since the car is designed to have some stagger.
Old Feb 23, 2007 | 01:14 PM
trust21's Avatar
what are you all paying for the replacement tires? and is everyone changing them all at once, or just the rears since they're the first to go. i'm approaching 19k on my stockers, so i need help too.
Old Feb 23, 2007 | 01:33 PM
ResIpsa's Avatar
It seems like we have a lot of tire experts in this thread. My suggestion, go take a trip to your nearest track and ask some of the drivers. I bet they tell you "put the biggest tires you can on your rim." And these are guys pushing their cars way beyond what 99% us would ever dare.
It's like the spacer myth. "The studs are going to break" or "your wheel will fly off". Then why does StopTech require spacers on most of its big brake kits? That company knows its kits are used in racing applications.
Personally, I have not seen a thread or heard of a single person having their VDC or anti-locks screwed up by tire size. Keep in mind, there are some wild wheel tire combinations on this board.
I am running 265/35/19 on stock rims. The tires are wearing even, my ADC (when I dont turn it off) works fine, and I drive the **** out of my G.
Old Mar 2, 2007 | 02:04 AM
mondo's Avatar
I put 245/35 & 275/35 Toyos on my stock 19s but my 15mm& 20mm spacers had to go.
The 15mm would work on the rear with a slight rolling of the fenders (my car is lowered with camber kit, otherwise I think 15mm would work). I'm probably going to go with 5mm & 10mm. I'm waiting on an order for 10mm Kics as their the only ones I found that have the studs mounted on the spacer with that thickness (if you know of any others, let me know).
I'm going to put them on the front and drive around a bit to see if they rub. If not, I'll roll my rear fenders and go 10mm & 15mm.
Old Mar 17, 2007 | 09:34 PM
Eric's Avatar
Viscous User
I'm thinking of going with the 245/265 setup. Can anyone who has this tell me their experience?
Old Mar 17, 2007 | 09:36 PM
Great fitment, plenty of curb protection. Car rides great, grips great. Ended up with Continental ContisportContact 2's.
Attached Thumbnails Best tires for OEM 19s-p3100001.jpg   Best tires for OEM 19s-p3100002.jpg   Best tires for OEM 19s-p3100003.jpg   Best tires for OEM 19s-p3100004.jpg
Old Mar 17, 2007 | 09:47 PM
Pratik's Avatar
Moderator
Moved to wheels/tires
Old Mar 17, 2007 | 10:46 PM
Beebo's Avatar
how much do the michelin pilot sports PS2s cost? i need tires bad!
Old Mar 18, 2007 | 01:48 PM
Finiti's Avatar
I'm looking at a set of Goodyear Eagle F1, any opinions on running 235/35/19 and 255/35/19?
Old Mar 18, 2007 | 04:40 PM
shimmy's Avatar
fyi: here is a tire size calculator to make sure your new shoes are roughly within OEM specs:
http://www.miata.net/garage/tirecalc.html
Old Mar 18, 2007 | 06:17 PM
  #30
lowrider's Avatar
I wouldn't run those sizes. Run 245/35/19, and 245/40/19 or 255/40/19. Both rears will work fine with VDC, and are within Tire Manufacturers Specs. I believe that a 265/35/19 rear would also work just fine on your factory 8.5" 19s, but they are outside of any Tire Manufacturers Specs.
Lou
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
