2005 6MT Alignment spec
Old Feb 23, 2007 | 11:21 AM
cicada06's Avatar
I lowered by car with Tein 350Z's H-Tech a couple months back and finally got around to getting an alignment at a local shop in Orlando. How are my specs?
Left Front
Caster: 8.9 degrees
camber: -1.8 degrees
Toe: 0.3
Right Front
Caster: 9.5 degrees
Camber: -1.5 degrees
Toe: 0.3
Left back
Camber: -2.3 degrees
Toe: 0.0
Right back
Toe: 3.1
total toe:0.6
Thrust angle: -0.3 degrees
Old Feb 23, 2007 | 02:44 PM
redlude97's Avatar
they did a poor job adjusting the camber and toe in the rear, the numbers should be close to the same left to right, even if they are out of spec. Its better to have matching out of spec numbers rather than numbers that vary so much left to right. If they can't get the left rear camber any lower, they should increase the camber on the right rear to match, and same with the toe settings. the fronts seem fine though
Old Feb 23, 2007 | 03:50 PM
cicada06's Avatar
thanks for the response. Should I look into camber kits?
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 18, 2015 12:33 PM
