Will 20" rims with +42mm offset rub???
Old Feb 26, 2007 | 10:00 AM
tigerville10's Avatar
Will they rub also if I drop my G 1.5 inches??? thanks
Old Feb 26, 2007 | 11:29 AM
Calvin's Avatar
Overglorified Altima
do you have a coupe or sedan? how wide are the wheels? what size tires will you be running?
cant answer your question without you first answering those.
Old Feb 26, 2007 | 01:03 PM
225/35/20 on the coupe. thanks
Old Feb 26, 2007 | 02:18 PM
Calvin's Avatar
i hope it's a super wide wheel, hah. a +42 offset is beyond terrible (in my, and most other peoples', opinion)
Old Feb 26, 2007 | 02:22 PM
Hi-TechG35's Avatar
^agreed... you may start shearing your strut if you running a high offset and wide rim
Old Feb 26, 2007 | 03:36 PM
redlude97's Avatar
i doubt the wheel is very wide if he plans on running a 225 on it, unless hes planning a superstretch which in that case we'll just have to let him figure it out on his own
Old Feb 26, 2007 | 08:13 PM
if i use a 225 tire and the offset is +42 and I roll the fenders will that be alright??? and will I be able to drop it also?
Old Feb 26, 2007 | 08:47 PM
redlude97's Avatar
you still haven't told us if its for the front or rear, and how wide the wheel is
Old Feb 26, 2007 | 09:33 PM
Deezflip's Avatar
I'm still trying to figure this offset lingo still...correct me if i'm wrong but the +42 offset would bring the tire closer towards the center of the car? So no fender roll is required however it might rub your strut/springs being that offset brings it close to the car. Higher offsets means closer to the face of the rim. Zero offset would bring it right down the center of the total width of the rim(resulting to a deep lip and bring the tire and rims out towards and away from the car.
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
TurTLe*
Sep 29, 2015 01:43 PM
