Tire pressure question.
Old Mar 8, 2007 | 08:01 AM
hokiesean24's Avatar
This is pretty novice, I know, but what kind of tire pressure are you guys running? I just put my new 19" GT-1s on less than a week ago and it looks like the fronts especially are pretty low on air. I would suspect it is mostly due to the fact that they were shipped from CA to VA and its like 20 degrees here right now. SO, I was going to put some air in them today during lunch but wanted to make sure I was putting the right amount. I am guessing they should still be somewhere in the 32-34psi range??
Thanks!
Old Mar 8, 2007 | 08:09 AM
GEE35FX's Avatar
I would start out at 34psi and see how they feel on the road.
Old Mar 8, 2007 | 04:00 PM
BadBoy06's Avatar
I tend to use an extra couple of pounds to help the rim
absorb blows.. <36>
Old Mar 8, 2007 | 04:23 PM
coolb's Avatar
Since I use 100Y Dunlop sport maxx in the rear and stock Pilot in front, my tire pressure is 35 for front and 40 for rear.
Old Mar 8, 2007 | 04:41 PM
I got the VA state inspection today and they set them at 33 all around...
Ill see how it feels before making any further adjustments.
Thanks!
Old Mar 8, 2007 | 04:45 PM
SilverII's Avatar
35 for me!
Old Mar 8, 2007 | 05:17 PM
coolb's Avatar
If I set 35 in the rear,the tires would be obviouely underinflated, which can be observed with eyes.
Old Mar 8, 2007 | 09:03 PM
Yeah, I still feel like they need more air... feels spongy or something. The front seems to want to catch and turn the car, I find myself hacing to pull it back a good bit.
Old Mar 8, 2007 | 09:08 PM
Andy2434's Avatar
35 psi cold all around.
Old Mar 8, 2007 | 09:32 PM
GEE35FX's Avatar
Put in a couple more pounds and see how it feels. It's not going to hurt. Try 35 lbs.
Old Mar 8, 2007 | 09:41 PM
ttrank's Avatar
Grocery getter
38 F/r
Old Mar 8, 2007 | 09:58 PM
wiz2's Avatar
^^^ I'm with him. I had mine intially set at about 40-41. Adjusted by 1 psi until i felt I had a good range for when teh got soem heat in them. Now I try to maintian 38 all around cold, it seems to feel the best.
Old Mar 9, 2007 | 08:46 AM
Yeah, I am def bumping it up...
Old Mar 9, 2007 | 08:57 AM
Brando's Avatar
Cool
Experiment and see what works best for your car. Are you lowered?
With my set up.....39 f & 38 r works best and keeps the tires from wearing as bad on the inside edges.
Old Mar 9, 2007 | 09:03 AM
not lowered...yet. I will be next Sat.
I think it may be an alignment / toe issue as well. All of that should be taken care of in the 4-wheel alignment after lowering, correct?
AND sweet ride Brando!!
Last edited by hokiesean24; Mar 9, 2007 at 09:03 AM. Reason: to give Brando a shout!
