How much PSI should the OEM 19" tires be at??
Old Mar 11, 2007 | 05:22 PM
Strtsk8r321's Avatar
Exclamation How much PSI should the OEM 19" tires be at??
My tire light has come on a few times with my new OEM coupe 19" wheels and tires. How many PSI are the tires supposed to be?
Old Mar 11, 2007 | 05:31 PM
redlude97's Avatar
did you swap your tps sensors over? thats more likely the cause
Old Mar 11, 2007 | 05:54 PM
no i just switched out the wheels and tires. I assume they had the tps sensors in them already.
Old Mar 11, 2007 | 05:57 PM
redlude97's Avatar
You have to go the dealership and get them to recalibrate them, they may have tps sensors, but they are set for each individual car.
Old Mar 11, 2007 | 06:00 PM
MRMEATY's Avatar
I keep mine at f39/b37psi.
Old Mar 11, 2007 | 06:12 PM
MRMEATY's Avatar
Are you losing air pressure or does the IL just go on?? You might have a leaking valve stem. Just had to take mine to the dealer to get one replaced.
Old Mar 11, 2007 | 06:21 PM
redlude97's Avatar
His problem isn't tire pressure, its his TPS sensors
Old Mar 11, 2007 | 06:39 PM
^^well I wasnt sure, that why I asked what you are supposed to keep them at, but I just checked and theyre all at 38psi. So I will just have them calibrated while I get my headlights replaced at the dealer (they cracked).
Old Mar 11, 2007 | 06:41 PM
617G's Avatar
CFW (Carbon Fiber Whore)
38psi? damn...that's a lot...check the tag on the door for recommended specs.
Old Mar 11, 2007 | 08:04 PM
The tag on my door has the recommended specs for OEM 17s.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
