Rims & Tires
Old Mar 12, 2007 | 02:52 AM
NewYorkG35x's Avatar
Rims & Tires
i am looking to buy these 20x8.5 20x10 zenetti flow rims with offsets 40 & 43 with toyo proxes t1r 245/35r20 and 275/30r20. i am going to have my car dropped 1-1.5" and i am going to get suspension mods around $1,700 worth. socks,sturts,springs sway bar ect. what my question is will my ride be still be rough with the suspenion mods??? becuase i have been told that those rims wll give me a rough ride but i want some more opinions. because we all knows rims look nice but if the ride sucks it can really **** ya off.i would recomend only experienced help prefered!!!!!!!!!!!!!!!
Please Do not post if you dont have much experience in this area!!Thanks
Thank you,
ANDY
Old Mar 12, 2007 | 03:02 AM
Tunerz_Store's Avatar
A lower profile tire couple with suspension mods is always going to give you a stiffer ride, especially if you go with stiffer spring rates.
Old Mar 12, 2007 | 06:46 AM
35bills's Avatar
What will you be using for suspension parts?
Are you going with adjustable struts?
Like the above post, your ride will be harsher than stock.
Old Mar 12, 2007 | 08:06 AM
seddon's Avatar
Looking at your screen name I am assuming that you have an X. If this is true then mostly you will be using Z springs, there are no aftermaket struts for the front unless you do custom, the rear you could change without any problems, there is also no sway bars for the X the rear might work but the front will not because of the transfer case. Any type of aftermarket wheels and tires will affect the ride quailty but honestly I don't feel too much of a difference in quailty with my 20's.
Old Mar 12, 2007 | 09:27 AM
Chico's Avatar
^^^+1. You should also consider same size all around as the staggered set up is not recommended for the AWD.
Old Mar 12, 2007 | 11:09 AM
ttrank's Avatar
Grocery getter
+2 you want to keep the same size wheels/tires on the "X".
I can tell you from experience that the Zenetti's will fit but you will have to roll your rear fenders. I had the Five's in the same size. My first combo was 1.3/1.2 H&R springs, stock sport struts, stillen sway bars and those wheels. The ride will be harder but not too bad. If you get springs that are progressive you won't feel the small bumps as much.
Old Mar 12, 2007 | 11:55 AM
thanks so far guys. well i havent decided on what suspension mods yet as of right now z springs or progressive springs liek ttrank said, sillen sway bar and i dont know what struts, any suggestions to make my ride better with the zenettis? liek what kinds so i can check them out.
Old Mar 12, 2007 | 01:35 PM
KrazyEd's Avatar
Just remember that springs that are made for the RWD sedan will drop the X approx. 1/2 inch more. So for instance, the Z springs drop the regulare sedan 1 inch and approx. drop the X 1.5 inches.
Old Mar 12, 2007 | 04:38 PM
yea i was debating if i wanted to drop it 1" or 1.5".
Old Mar 12, 2007 | 04:41 PM
KrazyEd's Avatar
I had the z-springs which dropped me 1.5 inches last summer on 245/40/19 tires. I had a lot of negative camber and I also had rubbing when I had 5 people in the car.
If I decide not to do the VRT coilovers I am either going to go z springs in front and coupe springs in rear or coupe springs all around.
Old Mar 12, 2007 | 05:06 PM
my mid is all over the place i want nice chrome rims but i dont want to ose my ride quality.
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
j_mullet
Aug 26, 2015 10:49 PM
Gip
Aug 24, 2015 05:31 PM
JaeXL
Aug 4, 2015 07:43 AM
