winter tires 245/45/18 front and back?
Old Dec 9, 2003 | 05:30 PM
scottkusf's Avatar
infiniti is telling me that since i cannot find a combo of 225/45/18 245/45/18 or 235/45/18/ 255/45/18 that i can put 245/45/18's on front and back. does anyone know if this is true or will it screw up the odometer, transmission, or VDC???
Old Dec 9, 2003 | 11:43 PM
miscreant's Avatar
Re: winter tires 245/45/18 front and back?
Answer 1: I think you'd be fine. Many people with 20"s put 245/35R20 tires on the front which are about as tall as the 245/45R18 tires.
Answer 2: Why can't you find 235/45 - 255/45 winters? They are available: HINT: www.tirerack.com..
And actually, they have the Dunlop M3s for $89 in 235/45R18 - you could use that on all 4 corners. Good deal.
<P ID="edit"><FONT class="small"><EM>Edited by miscreant on 12/09/03 08:47 PM.</EM></FONT></P>
Old Dec 12, 2003 | 02:06 PM
ryoken's Avatar
Actually, it will think the rear is slipping. The larger front tire will spin slower at the same speed. The system expects the front tires to be spinning a little faster than the rears normally.
The system probably has enough tolerance built in so that it won't constantly think you're slipping when you're driving straight and normal -- however, it will probably kick in a little earlier than otherwise.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
wojowojo16
Jul 27, 2015 09:57 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
apintojr
Jul 23, 2015 10:52 AM
Kicknshift
18 Inch
Jul 22, 2015 04:13 AM
