Need help calculating offset please ...
Old Mar 16, 2007 | 03:26 AM
terrycs's Avatar
The following configurations have been done on lowered 07 sedans without rubbing:
Car 1-
Front: 20x8.5/+34, 245/35/20
Rear: 20x10/+40, 275/30/20
Car 2-
Front: 20x8.5/+35, 245/35/20
Rear: 20x9.5/+43, 275/30/20
My question, if I try for:
Front: 20x9, 255/35/20
Rear: 20x10, 285/30/20
What should my offsets be to clear fender shifting wheel/tire inboard? Is it +23 front and +35 rear?
Old Mar 16, 2007 | 03:49 AM
rookie's Avatar
Wrong way, you need to go higher on the offset to account for the additional tire width.
Old Mar 16, 2007 | 03:52 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
noooo way your gonna fit a 9 up front with a 255 or a 10 with a 285.
If you're gonna go with a 9, then the offset needs to be atleast +40 with a 245/35. The rear can be +40 and higher with a 275, you'll have a world of problems trying to shove more rubber in there, stick with the standard sizes.
-GP-
Old Mar 16, 2007 | 02:36 PM
terrycs's Avatar
-GP-
Based on the 2 examples, can you tell me how you calculated +40 for front and rear? Increasing offset moves tire inboard, but increased width moves tire outboard.
Old Mar 16, 2007 | 04:30 PM
terrycs's Avatar
Ah .. I see. That makes sense. Thanks for straightning me out.
New calculations then -
The Following calculations assume no rubbing on inside.
From rear of car 1,
Given: 20x10/+40 and 275/30/20
Changing from 275 to 285 means 10mm more width (5mm more on each side). To move tire 5mm inboard means add 5mm to offset. Therefore, offset should be +45mm, right?
From front of car 1,
Given: 20x8.5/+34 and 245/35/20
Changing from 8.5” rim to 9” rim the wheel width grows .5 inch or .25 inch (6mm) each side.
Changing from 245 to 255 means add another 5mm to offset.
Therefore, offset should be +45mm as well, right?
On the S, the stock wheel/tire:
18x7.5/+45, 225/50/18 front
18x8.5/+50, 245/45/18 rear
Doing the math for stock wheel, offset+1/2 wheel width=
140.25mm front
265.9mm rear
Doing the math for 9” front and 10” rear, each with +45 offset:
159.3mm front
172mm rear (means more clearance than stock?)
What did I do wrong?
Old Mar 18, 2007 | 04:44 AM
terrycs's Avatar
Btt
Old Mar 20, 2007 | 03:34 PM
terrycs's Avatar
BTT - anyone?
Old Mar 20, 2007 | 03:41 PM
all the calculations dont make sense to me, i hate math!
Why dont you just stick with a 8.5F +35-40/10R+40-50 setup like everyone else??
-GP-
Old Mar 20, 2007 | 04:13 PM
rookie's Avatar
I didn't see your first bump, but your in depth post confused the hell out of me.
Car 1-
Front: 20x8.5/+34, 245/35/20 24mm wider stance than stock
Rear: 20x10/+40, 275/30/20 29mm wider stance than stock
Car 2-
Front: 20x8.5/+35, 245/35/20 23mm wider stance than stock
Rear: 20x9.5/+43, 275/30/20 20mm wider stance than stock
Your Car-
Stock
I don't own a G35 so take this with a grain of salt. Seems to me if you take the least aggressive of the 2 sample car rear offsets you should be fine using the rear tire you're looking to run. Front looks like it would the most to be concerned about since the wheel turns and could rub during suspension loaded turns.
20x9 +45 would give you bring you in 4mm less than the sample cars, but this also makes you inner clearace 16mm less than the sample cars which is 19mm less inner clearance than stock.
20x10 +49 would be equal to 20mm wider stance than stock but the 10" wheel reduces your inner clearance by 18mm.
The good thing for you guys is lot's of tires to choose from and all are relatively in the stock height range.
Picture Share
Feb 4, 2018 12:41 PM
mbe32
Nov 13, 2015 11:09 PM
NyCrAzY
Oct 1, 2015 09:19 AM
TurTLe*
Sep 29, 2015 01:43 PM
