Tein H Tech/ S Tech
Old Dec 13, 2003 | 09:56 PM
court's Avatar
Tein H Tech/ S Tech
Does anyone here have the Tein H tech or S tech springs?
Thinking about getting one but want to know the ride quality of both. Thanks I will be getting the springs in one week and need info on the ride quality on the G.
04 G35 Sedan Blk/Blk
Nissan Badges
Old Jan 11, 2004 | 01:57 AM
AznIceRckt's Avatar
Re: Tein H Tech/ S Tech
i wouldn't recomment the high tech. i have them , and they are very soft. stiffer then stock in the front, and the car certainly is much stiffer and rolls less, but i overall do not like them.
i chose them because they lower a good amount in the front, without lowering too much in the back. i suggest you go with tein basics or eibachs. tein s techs seem to lower the car a lot (2" drop? come on!). tein basics are only 500 or so more then tein springs. thats the road i am going once i get some money.
*** 2003 G35s 5a/t / Pearl White ***
~ Black Racing / Dunlop / Tein / Hotchkis / Blitz / Hks / Greddy / A'pexi / Sparco / Nismo / Alpine / Mb Quart / Sony ~
Old Jan 11, 2004 | 03:20 PM
Gsedan35's Avatar
Well it makes sense for one to say both springs are very soft, they use spring rates that are softer than oem and only 11lbs stiffer in the front with the S-tech. Plus they transfer a large abount of roll stiffness to the front, meaning they will increase understeer. Of course it depends on what you care about and how your willing to take into account known tuning laws. Front to rear balance differences listed below won't amount to much up to 5% or 10%. Go beyond that and they will make a difference, what will matter is if you choose to care about what the large differences on some setups will do to how your car ends up behaving. Buyer beware, people tend to not admit when a given setup has some negitive qualities, they tend to only talk about the good. Negitive reports are theirfore rare, but that does not serve other members well. We need to hear the good AND the bad on product reviews. And to many people rush to post reviews without sufficient mileage on the new setup.
Stock spring rates (Linear) F/R in lb/in
350Z and G35 coupe: 347/419
G35 sedan with sport: 357/407
Tein H-tech for G35 Coupe & Sedan
F/R Progressive spring rates listed rates are final rates
324/263
S-tech
358/274
S-tech front to rear spring rate balance to OEM balance
+3% front -33% rear (transfers 30% to front)
H-tech front to rear spring rate balance to OEM balance
-7% front -35% rear (28% transfer to front)
Eibach progressive (initial & final rates shown)
G35 sedan 259/334 front 359/413 rear
Front to rear balance to OEM using final rates
-4% front +1% rear (5% to rear)
On the Tein Basics I have serious concern on the amount of drop the have in the front on the sedan and their front to rear spring rate balance transfers to much to the front at 17% (ok it's not as bad as some, but I do not want more understeer) Setting them up per Tein's instructions you will drop the front 2.5" and the rear 1.1". The max they can be set to is a 1.6" in the front and no drop in the rear. Problem is 1.6" is to low for me and I highly doubt that the front springs will remain under load towards full suspension extention. My solution would be to buy a pair of 1" taller front springs from Tein ($165) that are also slightly softer
Tein Basic Coilovers
350Z/G35 Coupe & Sedan
F/R spring rates Linear springs
504/504
Front to rear spring rate balance change VS OEM on
350Z/G35 Coupe
+45% stiffer front and +20% rear (25% transfer to front)
G35 Sedan w/sport +41% front +24% rear (17% transfer to front)
If 448lbs springs are run in front balance VS OEM
changes to:
350Z/G35 Coupe +29% front +20% rear (9% transfer to front)
G35 sedan w/sport +25% front +24% (1% transfer to front)
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jan 17, 2004 | 01:29 AM
cupid's Avatar
What do you mean softer? Is the ride less stiff and car will noticably wobble more? (move up & down)
I'm interested in lowering the car. People say do not go with Eibach spring. So I'm looking at buying Tein spring.
TEIN H tech gives only 0.6" so I want to go with TEIN S.tech solution which will give me 1.2" drop.
Let me know in the long run if this will cause problem to my struts (shock absorber) and I will start bottoming-out.
Anyone who has installed Tein S.Tech have any feedback or comment?
2004 G35 Coupe | 6MT | Aero-kit 4-piece | Premium | Ivory Pearl | Graphite Lthr
Old Jan 17, 2004 | 02:26 AM
cupid's Avatar
How much should I expect to pay for installation fee to get the Tein Springs put on?
I want to get avg. install price so that I don't get ripped off.
thanks
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
bigmike
Sep 17, 2015 01:58 PM
