Tire size for rims
Old Apr 11, 2007 | 02:37 PM
pezzonovante's Avatar
Tire size for rims
Will the stock 2004 6MT 18" Pilot Sports fit on rims with the specs below? I'm thinking of upgrading
I get the offset stuff and it's close to stock so should be ok, but I'm not sure about tire sizes. I would think the these fronts would be ok width wise since it's only .5" wider than stock and the tire should still fit. These rears are 1.5" wider than stock, so the tires are probably not wide enough. How do I figure out the tire width to the rim width? Also, any idea if they will fit over the Brembos?
ADR Wheels Spartan
Bolt Pattern: 5x114.3
Size: 18"x8.5" FRONT 2" LIP/ 18X9.5 REAR 3 " LIP
Offset: +28mm front/ +25mm rear
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
