Coupe owners - how long does your tires last you?
Old Apr 16, 2007 | 11:18 PM
bocatrip's Avatar
I went to the Movies the other day and noticed a Coupe with 17s that absolutely zero tread on the rears. Totally and completely bald. Some people are crazy or just stupid. I'm sure that many conservative drivers are not even aware that they need tires until the dealer brings it to their attention. In some cases, our tires look good from the outer tread, but only when we get under and look carefully can we see the wear.
Old Apr 17, 2007 | 11:02 AM
CBRworm's Avatar
20 Year Member
I am not as bad off as I thought. 2 of my 4 18" sedan tires (NCT-5) are not round anymore and need to be replaced, but still have about half the tread left. I am just over 30K. I guess it could be worse. It has really been bothering me that I need to replace my brake rotors and tires at 30K with plenty of 'life' left in both pads and tread.
Old Jul 20, 2007 | 03:30 PM
05dggcoupe's Avatar
New to forum and having problems with 05 coupe front tires
i have an 05 coupe and i have just barely over 21.5k on the front tires. i took my car to the local nissan dealership to have the rears replaced and they told me that my front tires are wearing heavily on the inside and they are also choppy.Does anyone else have this problem with the stock 19s on an 05 coupe?
Old Jul 20, 2007 | 03:54 PM
SilverII's Avatar
21.5K on front tires = GOOD!
Old Jul 20, 2007 | 04:04 PM
izmir41500's Avatar
G35driver Addict
coupe oem 19" potenza re050 - 25k miles.
Old Jul 20, 2007 | 04:22 PM
Voodoo's Avatar
CCT-we call down the rain
Changed to Nitto's 555, got 15K on them with still another 10K or more left.
Old Jul 20, 2007 | 04:33 PM
BadBoy06's Avatar
Originally Posted by ieatmangosnaked
I have an 05 coupe and with the oem 19's on them. I had to replace my tires after 32,000. I was lucky to even get that far with them.
DAMN
Old Jul 20, 2007 | 04:36 PM
JOKER's Avatar
CLUB MODERATOR
It's not the car you have to blame it on. It's the driver.
I killed my first set in 20k
Now I'm on the second one with 46k on the car and tires are still very much brand new. So it's all about the gasket between the seat and the steering wheel.
Old Jul 20, 2007 | 04:38 PM
JOKER's Avatar
CLUB MODERATOR
they do that all the time. Allows the car to handle better once you go into the turn.
Old Jul 20, 2007 | 04:43 PM
TURBOTOM's Avatar
a.k.a kleicoupe
i got about 10k on my OEM tires. I got 20k on my t1r rears, and 22k on my t1r fronts.
Old Jul 20, 2007 | 06:36 PM
Hitman_'s Avatar
22.5K miles results
The rear tires have word down quite a bit more quicker in the middle of the tires. Could be cause I sometimes give it a bit more gas when taking off causing some tire burn.
Fronts have only a bit of wear on the outside, not the inside as some report here. But at this state, the front tires are humming in need or replacement and in need of a front end alignment.
Still on the same tires for about 3K and then they are gone.
Old Jul 20, 2007 | 06:55 PM
joeygott's Avatar
Coupe tires....MESSAGE FOR BOCA
Why wouldn't the dealer install a camber kit vs replacing your tires regularly?
Old Jul 21, 2007 | 01:32 AM
JOKER's Avatar
CLUB MODERATOR
I never hear dealer replacing no tires.
there is no camber kit needed.
If you put camber kit on then G will b like a boat in turns.
Old Jul 23, 2007 | 02:47 PM
blksnake's Avatar
'04 G35 Coupe -
Alignment every 6 months
Goodyear Eagle RS-A OEM 17" = ~28k (Still had some thread left before I replaced them)
Michelin PS 18" = ~32.5k (Need to replace)
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
tiguy99
Jul 26, 2015 01:39 PM
itschuckster
Jul 25, 2015 08:07 AM
realtalk21
Jul 20, 2015 09:07 AM
papo020
Jul 17, 2015 10:30 PM
