SSR Agle Strusse
SSR Agle Strusse
What do you think of these? I'm shopping around and haven't seen anybody with these yet. Is there anything wrong with them (offset, quality, weight, etc)?
Russ
Black w/willow, 6MT Coupe, Nav, Aero, Nismo CAI, V1, PS2, AVelectronic Tuner, Headrest Monitors, Splash Guards..
Jax, FL
Russ
Jax, FL
Re: SSR Agle Strusse
They make all of the different sizes for our cars. I'm looking for 19x8.5, 19x9.5.
Russ
Jax, FL
Russ
Jax, FL
I have the SSR agle minerva's SMC. I don't know if the Strusse's are similar, but I had problems with getting the right size to fit over the front brembo's. SSR didn't make the right offset so I have to use a 5mm spacer on the front. The over all qaulity of the 3 piece rims are great. The SMC seems to be brighter then chrome, but a pain in the *** to clean and avoid scratching.
I don't know what size your going with, but I went with 20x10 rear and 20x9 front. After putting S03's on the rear was about 20lbs more then stock and the front was about 15lbs more then stock. I have all the weights written down somewhere if you need it. You get great handling, but a little bit of a difference on excelleration.
What offset did you have to settle for? I think I'm going with 21 front and 23 rear on 19x8.5 / 19x9.5. After you put in the spacer were you able to get your camber back to stock?
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
Russ
Black 6MT Coupe
Jax, FL
According to SSR, the proper setup for the G35 coupe is a 19x9 +24 front with a 55mm lip, and a 19x10 +24 rear with a 82mm lip. This is the sizing reccomended on SSR's site, so it should fit no problem over the Brembos.
-Colin
Here's the link http://www.speedstar.co.jp/collectio...ing/nissan.htm
-Colin
Thanks for the info. That's a pretty big lip. What is the GC35 on that chart?
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
Thats for the non brembo Skyline. If you look at the letters in ( ) after the offset, thats not the right disc to clear the brembo's. You'll need a (HP) for the front, and youll still need the 3 or 5 mm spacer to clear. And a (MD) for the rear.
04 6MT, Black, Aero, Prem, Tein Flex's, Cusco sways, 19" SSR Sovereign's, Clears, 350Z Pedals, No front plate!
