How to fit lexus wheels on my g35
Old Apr 30, 2007 | 11:26 PM
akachi's Avatar
is ur G coupe or sedan?
those offsets are good for sedans
15mm spacers should by sufficient
Old Apr 30, 2007 | 11:43 PM
G SEDAN's Avatar
this sounds way too aggressive...33mm rear with 20x10 will not work at all.........10 inch wheels are the very limit that you can do on the sedan and your target offset is at 40mm rolling fenders......the front 20x8.5 will need at least a 38mm offset and 27mm is way too low. I dont know what the center bore issue is....but given the offset problem after the spacers.......i'd conclude these wheels will not work at all on the sedan man......hope this helps.
Old May 1, 2007 | 12:02 AM
02themax's Avatar
Can't you get it over bored? Call some machine shops and see??
Old May 1, 2007 | 12:11 AM
nghiars's Avatar
what do you mean by center bore? did you only try to fit the front rims on? because everywhere newbe trying to put rims on there front always forget to take the "extra" bolt off the front rim that ppo think is to keep ppo from rotating their wheels.. its actually used for removing the rotor when its stuck on too tight oer time... if its rims off of a GS im pretty sure they'll fit without much, if any, work at all
Old May 1, 2007 | 12:37 AM
G SEDAN's Avatar
Since this is the sedan section..I'm assuming he has a sedan and his car did not come stagger factory. With that said...he does not have the extra bolt that's on the coupe....Also......I'm guessing center bore means his lug hole is not big enough for the G35...
Old May 1, 2007 | 01:00 AM
(>")> G35's Avatar
What kinda of wheels are they? Most wheels are universal bored (73.1mm), so maybe there's a hub ring stuck inside the wheels?
Old May 1, 2007 | 02:16 AM
papiloco21's Avatar
you need a hub ring
Old May 1, 2007 | 02:18 AM
(>")> G35's Avatar
If his wheels are indeed bored 60.1mm (lexus), there's no way a hub ring is going to make them fit.
Old May 1, 2007 | 02:36 AM
ttrank's Avatar
Grocery getter
There is no way to make those wheels fit without the major risk of damage and making them too weak. I would sell them and get a set to fit the G (which is 66.1mm BTW).
Old May 1, 2007 | 02:37 AM
ttrank's Avatar
Grocery getter
Originally Posted by papiloco21
you need a hub ring
No...
