i need help on wheel/tire combos
Old May 4, 2007 | 03:03 AM
cv5boi's Avatar
hello all i am new here and i do not know much about g35's and i greatly appreciate some help thanks
i have a 04 g35 coupe w/ brembo brakes
and im thinking about purchasing axis milanos 20 inch
Two 20x8.5" (15mm offset) and Two 20x9.5" (25mm offset)
they say it will clear brembo brakes so thats not a issue...
but what tire combo should i use for the fronts and the rears?
thanks in advance
Old May 4, 2007 | 06:10 AM
empfl's Avatar
alot of people go w/ 245/35/20 fronts with 275/35/20 on the back.. i suppose you COULD bump it to 285 but i hear that with the 20's.. you'll probably need to do some fender rolling which would be a pain in the ***..
just for reference
the first number would be the width of the tire in mm
the second number would be the width between the tire and the rim
the third number is the size of your rim (not tire) in your case it would be 20
GL w/ your purchase.. if you look in the wheel section there's a bunch of info on tire size
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
SuperSaiyan
Sep 23, 2015 06:13 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
