Hartge Classics
Old Jan 1, 2004 | 07:27 PM
EvolutionGSR's Avatar
Hartge Classics
Does anyone know if Hartge Classics will fit the bolt pattern on the G35 coupes? If not does anyone know the bolt pattern for the car? I can't seem to find it anywhere.
Old Jan 1, 2004 | 08:09 PM
Rob_G35's Avatar
In Search of Magic
Re: Hartge Classics
The bolt pattern on the g35 is 5 X 114.3
2003 CB Coupe 6MT
Z-tube
Stillen Hi-flow
Old Jan 2, 2004 | 07:04 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Re: Hartge Classics
Hartge are Built Just for BMW's
Bmw's are 5 x 100 bolt pattern, and Not sure what offset, But if You Must Get Hartge see if you can get Un Drilled ones and get them drilled to 5 x 114.3 or just buy the BMW ones and take them to a welding shop have them weld the holes up with new aluminum and then re drill them to the correct bolt pattern. Lots of Work But Dare to be Different.... Good Luck
Death Has Gotta be Easy. Because Life is just so Hard. It'll Leave you Physically, Mentally, & Emotionally Scarred. "50 CENTS"
NismoCPV-35
Old Jan 2, 2004 | 08:10 PM
ducatiguy's Avatar
Premier Dough Slapper
Re: Hartge Classics
Too much work, not to mention if they're forged, you don't want to be welding on them. If you must have em, simply get bolt-pattern adapters. Easy as that...
"See, the problem is that God gives men a brain and a *****, but only enough blood to run one at a time."
Old Jan 3, 2004 | 11:50 PM
Re: Hartge Classics
yah i knew they only made them for bmw but i was hopeing there would be a bolt patter than matched up. as far as getting undrilled rims....i never knew that was an option, where can you get that?
Life is hard, but its harder when you're stupid.
www.1911forum.com
www.calguns.net
Old Jan 4, 2004 | 11:20 AM
ducatiguy's Avatar
Re: Hartge Classics
Once again, drilling out a rim, should always be your LAST option, and quite frankly, I can't see how you would be able to on the HC's, so don't even consider it. Your ONLY option is to get a set of bolt pattern adapter, if they can accomodate your request and application. With so many rims out there, any reason why you're so hooked on getting a set of wheels designed for and marketed for a BMW?
Old Jan 6, 2004 | 06:21 AM
Re: Hartge Classics
Why i want HC's? I dont know, just a thought. I like the way they look, and they look better than other spoked rims out there. Theres no real reason, but since its seems to be so complicated i've concluded that i won't be getting HC's, and am in search for something else now, although i dont know what it is.
www.1911forum.com
www.calguns.net
snic09
Nov 8, 2017 01:46 PM
PZ06G
Aug 27, 2015 06:11 PM
