295/30/19 on 19x10.5
Old May 15, 2007 | 12:57 AM
fherjohn's Avatar
will this be too wide on my meisters with a +22 offset? Im not sure if i really want that stretched look thats why. BTW my fronts will be 255/35/19 on 9.5. Is there a reason why people go with diffrient tire thickness sometimes like 35 front 35 rear? any help would be great. thanks
Old May 15, 2007 | 09:47 AM
gspotter's Avatar
30 is not the "thickness"- it's called the aspect ratio. 30 means the tire height is 30% of the tire width. So, different width tires with the same aspect ratio will have different thicknesses.
Old May 15, 2007 | 02:42 PM
nyqueenz's Avatar
man 9.5 in the front IMO that's ugggg the most I would do is a 9 up front.. tooo much lip unless you going widebody
Old May 17, 2007 | 08:44 AM
go coogs's Avatar
i have 275 on my rear volks which are 19x10.5 because i diddn't want rubbing issues when its lowered, i say go for 295 if your not going to lower it or if you are i personally wouldn't go with anything bigger than 285, just my personal preference though
Old May 17, 2007 | 10:27 AM
fherjohn's Avatar
cool. i am going to drop it, i might just go with 285 but roll my fenders then. i just wanted some meat on my tires to protect my rims
Old May 17, 2007 | 11:08 AM
Calvin's Avatar
Overglorified Altima
9.5 in the front is probably the most common/popular setup for the coupes. the width of the wheel is not going to be the final determining factor of lip size either...
Old May 17, 2007 | 11:10 AM
617G's Avatar
CFW (Carbon Fiber Whore)
Originally Posted by aHero4Eternity
9.5 in the front is probably the most common/popular setup for the coupes. the width of the wheel is not going to be the determining factor if lip size either...
+1...it's a combination of offset and width that determines the lip size
Old May 17, 2007 | 01:57 PM
sen_jen's Avatar
Meatshake Enterprise
^ word to aHero4Eternity. also, coupes can run 10" width wheels on the front with still adequate amount of lip no problem
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
