alignment necessary after getting new aftermarket wheels?
Old May 17, 2007 | 10:14 PM
cash20's Avatar
do ya'll think i need to get an alignment after putting on my new aftermarket wheels? replacing current oem 19s with wider 19s wheels and tires.
Old May 18, 2007 | 12:37 AM
ttrank's Avatar
Grocery getter
It's always a good idea. Most shops will check it for free.
Old May 22, 2007 | 11:40 PM
az1anbeethoven's Avatar
no, you will not need an alignment by changing wheels...only if you mesh with the suspension geometry which means if you change your springs or adjust your height if you have coilovers...
Old May 23, 2007 | 09:47 AM
cash20's Avatar
thanks
Old May 23, 2007 | 12:16 PM
b00stedjustin's Avatar
you always need an alignment after suspension work, new wheels, or just new tires.
Old May 23, 2007 | 12:31 PM
617G's Avatar
CFW (Carbon Fiber Whore)
wtf r u talking about? why would you need an alignment when swapping wheels or tires? your suspension doesn't change...the only time you need an alignment is after lowering your car, adding new A-arms, toe links (etc..), or after driving around for a few thousand miles. Your alignment specs don't change when you pop your wheels off to put new tires on.
Old May 23, 2007 | 01:24 PM
Jeff92se's Avatar
Red Card Crew
Old May 23, 2007 | 01:33 PM
redlude97's Avatar
not always true, offset does play a roll in the suspension geometry because it changes the effective lever arm applying force to the springs. This is the case when you switch from a high offset wheel to an extremely low offset wheel. If you are already on the edges of the alignment specs, changing to a low offset wheel and push you out of the accetable range.
Old Jun 24, 2007 | 11:26 PM
absolutg's Avatar
workin...
what's the concensus here? i'm bumping this thread to get more opinions.... if i'm going from stock 18's to wider and staggered 19s, will i need to get an alignment done?
Old Jun 24, 2007 | 11:39 PM
GEE35FX's Avatar
Depending on your driving habits.
It is a good idea to get the alignment checked once a year or at least monitor the wear on your tires for any abnormal wear patterns. If your tires are wearing good then it is not necessary.
Old Jun 24, 2007 | 11:43 PM
absolutg's Avatar
workin...
hmm. ok, i guess when i get my wheels swapped, i'll check how my 18s were wearing. i realized it's been a little over a year since i got an alignment and i drive on some $hitty roads now (stupid SF). i just don't want to chew through tires next weekend on our norcal run.
Old Jun 25, 2007 | 01:51 AM
panda007's Avatar
QFT... that's why most of the time when people swap out their wheels and tires, they also drop the car to minimize downtime and expenses for alignment.
Old Jul 10, 2007 | 12:25 AM
PSD G35's Avatar
I just went from factory 18's to 20's. Went to get my alignment checked and there was a 1 degree change. I asked the wheel guy why so much of a drastic change...he said it was because of the difference in wheel size and offsets.
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
BlackGee35
Jul 23, 2015 01:36 PM
