Should I go with 285/30/19 or 275/30/19 on 9.5" ?
Old May 24, 2007 | 04:26 PM
GTT's Avatar
GTT
G35 Twin Turbo
I'm about to buy new tires, and i was wondering should i go with 285 or 275 on 9.5"? also, the offset for the rear tires is +25, do i need to get spacer if i want my wheels flush with the fenders ?
Regards
Gdup35sedan's Avatar
ENVautoDetailing.com
you can easily fit a 285 under there with a +25
-GP-
Old May 24, 2007 | 04:50 PM
GTT's Avatar
GTT
G35 Twin Turbo
Thanks I just placed an order from onlinetires.com
I don't think anyone can beat this price
Toyo PROXES T1-R $246.00 2 Size: 285/30/19 98Y* $492.00*
Toyo PROXES T1-R $196.00 2 Size: 245/35/19 93Y* $392.00*
Shipping - UPS Ground: $42.01
Order total: $926.01*
Old May 24, 2007 | 04:51 PM
redlude97's Avatar
neither one of those sizes are correct, you should be running 275/35/19 or 285/35/19 on a coupe
Old May 24, 2007 | 05:00 PM
GTT's Avatar
GTT
G35 Twin Turbo
r u sure ? I have asked many times no one told me before
Old May 24, 2007 | 05:04 PM
redlude97's Avatar
put it in a tire calculator yourself. Stock size is 245/40/19
http://www.miata.net/garage/tirecalc.html
why listen to others when you can do the research yourself?
superdds's Avatar
+1...also 30 series would look stretched and not offer much wheel protection.
Old May 24, 2007 | 05:05 PM
redlude97's Avatar
how would the series of tire effect the "stretch" of a tire? Only the width of the tire does that
Old May 24, 2007 | 05:09 PM
GTT's Avatar
GTT
G35 Twin Turbo
thanks for telling me, i guess I'm gonna give them a call
Old May 24, 2007 | 05:14 PM
GTT's Avatar
GTT
G35 Twin Turbo
I just change it
245/35/19
285/35/19
I hope i got the right one this time
Old May 24, 2007 | 05:18 PM
redlude97's Avatar
I just change it
245/35/19
285/35/19
yup, those are the exact sizes I run, though I would bump the fronts up to a 255/35/19 if its available
Old May 24, 2007 | 05:22 PM
GTT's Avatar
GTT
G35 Twin Turbo
^ thanks redlude97 for the info
Old May 24, 2007 | 05:48 PM
superdds's Avatar
i thought he's running 275 on 10.5. 275 looks a bit stretched on 10.5...couple that with a thinner wall tire like 30 series, it will definitely offer less wheel protection.
Old May 24, 2007 | 06:28 PM
ttrank's Avatar
Grocery getter
A lower profile means less sidewall and thus more of a stretch if you are running a tread patch thinner than the width of the rim. I have tried both a 275/30/20 and 275/35/20 on my car; the 30 looks quite a bit more stretched but I went with it because it is very close to my stock diameter.
Old May 24, 2007 | 06:32 PM
redlude97's Avatar
not a 285 on a 9.5 though, which is what we are talking about, a 285 will actually slightly bulge on a 9.5" wheel
