60 degree cone seat nuts
Old May 29, 2007 | 09:37 AM
clinthammer's Avatar
According to Work Japan (for the VS-XX) I need to get those lugnuts for the rims.
NOw does anyone know if stock nuts can fit or where can I get these specific nuts - since Work Japan obviously doesn't have it.
Old May 29, 2007 | 03:54 PM
bert039's Avatar
Pretty much all of the "tuner" lug nuts fit this criteria. You could go with:
Work, Volk, Mcgards, Muteki, Project Kics, etc...
You should not use stock nuts on your Work rims. Not even sure if they'll fit in the holes. I'll have to look again, but a lot of stock lugs have an "acorn" style seat, so it won't match quite as well with the typical aftermarket "cone" seat. I forgot what the stock G lugs looked like.
I went with Mcgard Spline Drives w/ Mcgard locks. The reason was because they are closed ended, to protect the studs from rust and the weather elements, they are weight matched with the locks, they require an additional "key" to remove them (additional security), they have a good reputation of being very durable, and they came in chrome (to match my silver rims). They're not JDM, but all of the other features made them more desirable to me.
Old May 29, 2007 | 04:19 PM
redlude97's Avatar
You must come from the honda club, only honda uses acorn style OEM lugs, the stock nissan ones are tapered much like every other "tuner" style. They are quite large in diameter however, so thinner lugs would be recommended
Old May 29, 2007 | 04:22 PM
bert039's Avatar
LOL Integra, just don't tell anyone.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
NyCrAzY
Oct 1, 2015 09:19 AM
doakley92
Sep 25, 2015 12:58 PM
