what tire PSI do you have on Toyo T1Rs
Old May 31, 2007 | 10:02 PM
cash20's Avatar
suggestions on tire PSI for Toyo T1-R 245/35/19 and 275/35/19. I know the stock tires were 35 PSI. just seeing what the other owners of the Toyo T1Rs with the same size put. let me know what ya'll got it on or suggestions so I can set mine accordingly.
Old May 31, 2007 | 10:45 PM
ttrank's Avatar
Grocery getter
I run 35psi in my Falken 452's. I would start there and see how it goes.
Old May 31, 2007 | 11:22 PM
cash20's Avatar
just worried about running 35PSI on low profile tires...the lip is pretty close to the floor..and these toyos have a soft sidewall..wondering if better to raise it to 38-40 psi
Old Jun 1, 2007 | 12:31 AM
ttrank's Avatar
Grocery getter
Mine are 245/35/20 and 375/30/20 at 35 all around. I have ran 25 before, you are fine.
Old Jun 1, 2007 | 12:32 AM
norcal_chan96's Avatar
35 psi here
Old Jun 1, 2007 | 09:09 AM
dovla's Avatar
Per Toyotech@ToyoTires.com email I received recently for T1R 265/35ZR18 275/35ZR18 on the track:
For air pressure. Start at 38-41 psi. (hot) Tune for best performance for your application.
As for the temperatures, 180-220 degrees is the best range. Optimal temp. is 200 degrees
Old Jun 1, 2007 | 04:59 PM
Meth68's Avatar
40 on my 285/30/20's here
Old Jun 1, 2007 | 05:16 PM
w0ady's Avatar
fgc moderator
245/35/19 and 275/35/19 running at 35psi for the past 2 years with no problems.
Old Jun 1, 2007 | 05:18 PM
superdds's Avatar
thirty five
jilljann1
Jul 21, 2020 08:12 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
yosip1115
Sep 9, 2015 03:30 PM
philthethrilloh
Sep 9, 2015 01:25 AM
