diff between fender shaving and rolling
Old Jun 3, 2007 | 04:30 PM
trueskillz12's Avatar
i've heard these 2 terms used before but never knew the difference or if there is a difference.
any insight?
Old Jun 3, 2007 | 04:49 PM
Calvin's Avatar
Overglorified Altima
rolling...you're just bending the fender back.
shaving...exactly what it sounds like - you literally shave the fender.
both have their drawbacks.
if you don't roll it properly, the paint can crack.
there is the potential of rusting if you shave your fenders.
a clean roll is favoreable over a shave.
fyi - the front fenders are already rolled. look at those if you want to see an example. also, search accordfreak's DIY in the DIY forum for a guide.
Old Jun 3, 2007 | 07:36 PM
hero i remember you got your rims @ f1
how did they go about with it?
my vsxx are in
just waiting on the toyo backorder
and hks rs backorder
Old Jun 4, 2007 | 01:56 AM
Calvin's Avatar
shaved.
Old Jun 4, 2007 | 02:06 AM
ttrank's Avatar
Grocery getter
I rolled mine. As long as you use a heat gun to keep the clear coat warm it works just fine.
Old Jun 4, 2007 | 01:33 PM
ltrrtl218's Avatar
why do they roll the front but not the back?
Old Jun 4, 2007 | 01:43 PM
redlude97's Avatar
The fronts have splash guards that attach to the fenders while the rears don't. Also, the front wheels turn which increase the likelyhood of rubbing, so they roll the fronts
Old Jun 4, 2007 | 05:35 PM
EEjiggapin0's Avatar
Originally Posted by aHero4Eternity
shaved.
you got yours shaved over at Wheel Supply right?
Old Jun 4, 2007 | 07:17 PM
droppin_deuces's Avatar
I had my fenders rolled over the weekend...a reputable body shop will be able to help you.
https://g35driver.com/forums/northern-california/160350-fenders-rolled-lic-motorsports.html
Old Jun 4, 2007 | 07:25 PM
Calvin's Avatar
f1.
Old Jun 4, 2007 | 08:29 PM
misSxhuStLer's Avatar
+1. my BF rolled my rear fenders for me using this method and it came out great. just make sure whoever does it for you really takes their time with it.
Old Jun 4, 2007 | 10:14 PM
f1.
you think i should go to f1 since i'm getting my rims from them, or go to wheel supply?
Old Jun 4, 2007 | 11:15 PM
aleok's Avatar
my friend with his Z tried rolling his himself, and said he barly rolled it, but the paint started to chip and crack. what should he do now? continue the roll or just shave it, and seal?
Old Jun 4, 2007 | 11:51 PM
redlude97's Avatar
crack on the inside or outside?
Old Jun 5, 2007 | 06:16 AM
aleok's Avatar
only the inside
