removing OEM wheels
Old Jun 11, 2007 | 12:46 PM
brianyun's Avatar
removing OEM wheels
i tried loosening the lugnuts but using what the factory gave it. do i have to use something different or just losen really really hard
Old Jun 11, 2007 | 12:52 PM
GreenGoblin's Avatar
The goblin resurrection
you can do it they will be tight the first time but some muscle into it or go buy a breaker bar with the correct size socket and that will make it 10x easier
Old Jun 11, 2007 | 12:54 PM
Hi-TechG35's Avatar
+1 or if you have a longer pole just slide it over the factory lug nut wrench and that should loosend them up. Also spray a little bit of WD40 or some lube on them to help loosen them up.
Old Jun 11, 2007 | 12:55 PM
RaFmAn123's Avatar
if i can get it i usually put the bar to where i can step on it and it will break free its usually hard the first time you take it out and also if you havent taken them out in a while. dont be afraid to put a little muscle in it.
Old Jun 11, 2007 | 01:05 PM
brianyun's Avatar
yeah. im like jumping on it and its not budging. haha i guess i should get fatter
Old Jun 11, 2007 | 01:06 PM
izmir41500's Avatar
G35driver Addict
lefty loosy. make sure you're not messin up your studs. slip a pipe or something over the lug wrench to get more leverage.
Old Jun 11, 2007 | 01:11 PM
brianyun's Avatar
yeah. i just got them off. thatnks for the help guys....
oh yeah one more thing. when i put them back on. i just gotta tighted them really really tight right? or do i need some type of machine to do it
Old Jun 11, 2007 | 01:44 PM
LjN_728's Avatar
Really really tight is good enough.
Old Jun 11, 2007 | 01:48 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
uuuuummmmmm..... NO.. you do NOT want to step on the bar, that's how people royally FUKC up they're studs. You always want to pull upwards with the bar.
Tighten the lugs by lightly by hand with the lug wrench, once they dont turn anymore with minimal force, turn them another 1/2-full turn. Then take the car to a tire shop and have them torque the wheels to 85 ft/lbs.
-GP-
Old Jun 11, 2007 | 05:13 PM
brianyun's Avatar
is it possible to over tighten?
Old Jun 11, 2007 | 05:49 PM
redlude97's Avatar
yes, and it can warp the rotors if they are overtightened
Old Jun 11, 2007 | 09:15 PM
HotRodW's Avatar
Buy a torque wrench and torque them yourself. A good wrench is not that expensive, and you'll get plenty of use out of it. You should always check the torque again after you drive the car for about 50 to 100 miles.
Xfactor
Dec 1, 2019 12:52 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
teamghost
Jul 28, 2015 04:52 PM
stay_tuned
Jul 21, 2015 07:09 PM
