Tire pressure sensors in new rims??
Old Jun 12, 2007 | 08:18 PM
g35_6gear's Avatar
Is everyone transfering their tire pressure sensors over to their new rims or going without? Any way to deactivate the TPS system??
Old Jun 12, 2007 | 08:33 PM
perry05G35's Avatar
If the sensor fit in your new wheels I suggest you get them swapped over I had my TPS put into my wheels and I'm glad I did. You would have to go to the dealer to get the TPS deactivated if you don't install them in your new wheels or else the TPS light will come on for the first 40 mins of your driving.
Old Jun 13, 2007 | 11:22 AM
trey's wife's Avatar
My horns hold up my halo
I swapped mine over and believe me that the guys who did the swap were very happy to see me leave. LOL Those sensors were almost impossible to get into the SSR's and they had to grind down the outside edges of a wrench to do it.
Old Jun 13, 2007 | 12:11 PM
DannyDeez's Avatar
I was actually going to post this question myself. What happens if you dont put them on new rims? Does the light just come on or is there something that will go wrong?(Such as the car cutting power or something like that?)
Old Jun 13, 2007 | 12:18 PM
spacecowboy's Avatar
or you could spend the extra 400 and get a new set of OEM TPMS and the valves instead of taking them off the stock wheels. This way, you don't have to put them back on the wheels when you switch to winter tires (provided the stock wheels are your winter wheels)
Old Jun 13, 2007 | 12:57 PM
Tiger's Avatar
Not true. The TPMS module will not recognize the ID of more than 5 sensors. You will have to get the car re-programed every time you swap the wheels.
They really charge $400 for those things? Another "rape by government mandate."
Old Jun 13, 2007 | 01:12 PM
http://www.tirerack.com/wheels/TPMSS...ModClar=&qty=4
there you go.
Old Jun 13, 2007 | 02:10 PM
Christian's Avatar
The owner of the shop that installed my winter tires told me that if I purchase aftermarket rims and do not install the TPMS sensors I could have a claim denied by my insurance company in the event of an accident. Scary thought! Is there any truth to this?
Old Jun 13, 2007 | 02:54 PM
EricIsKlumzyee's Avatar
^ No he just doesnt want to do it lol
careful when grinding down the rim to make the Sensor fit.. you MAY have a leak afterwards.. IMO just run without it.. Also by law you are no tallowed to deactiviate the TPMS system!
Old Jun 13, 2007 | 03:32 PM
redline9001's Avatar
that is BS... it should hold 9, there is another $100 to the dealer every six months
Old Jun 13, 2007 | 03:33 PM
how about rim failure... and if you are grinding down your wheel you just voided any warrenty on that wheel...
Old Jun 13, 2007 | 03:40 PM
Christian's Avatar
Funny thing is he told me not to purchase any after market rims, instead he told me to stick with the stock wheels with the TPMS.
Old Jun 13, 2007 | 03:51 PM
^ you have a strage one? maybe its a different law in canada?
Over here insurace will cover anything thats on your car
Old Jun 13, 2007 | 04:28 PM
trebien's Avatar
Just to be clear, the anecdote above... the mechs had to grind down a wrench to make it fit during the install process... not a rim.
Old Jun 14, 2007 | 12:05 AM
Thank you! I was just about to clarify that. They did NOT grind the RIM - they ground the outside of the wrench to make the WRENCH fit in the space with enough room to turn in order to install the TPMS without popping the rivets out.
