anyone running 245/35 and 275/30 19inch
Old Jun 19, 2007 | 09:16 PM
g35brother's Avatar
Anyone running the above setup? 275/30 tires are so much cheaper. My concern is the VDC being thrown off since the rears will be smaller then the fronts.
Anyone?
Old Jun 19, 2007 | 09:18 PM
redlude97's Avatar
don't do it, they are shorter than the front tires and look retarded IMO. It will also throw off your speedometer and odometer readings along with the possibility of messing with the VDC
Old Jun 19, 2007 | 11:10 PM
G3rider55's Avatar
i think it looks ok..it helps against rubbing issues (depending on your setup) im running 35s front and 30 rears and have had no problems....
Old Jun 20, 2007 | 06:36 AM
aleok's Avatar
I'm running that set up, not because its cheaper but to help prevent rubbing, and the actual diameter's are pretty close.
Old Jun 20, 2007 | 01:59 PM
redlude97's Avatar
Thats the whole problem, the rears are supposed to be taller. Rubbing is dealt with by rolling your fenders, not using the wrong sized tire
Old Jun 20, 2007 | 02:34 PM
shibal_z's Avatar
I'm using Michelin PS2 275/35/R19. No drop. No rubbing and it's closest to the OEM circumference. I would vote against using the 30 profile.
Old Jun 20, 2007 | 05:28 PM
aleok's Avatar
well its looks better....
Old Jun 20, 2007 | 05:46 PM
Nismo G's Avatar
Im running that same set up and it looks completely fine. The rear end of the car does not look lower than the front in anyway, it actually looks level. When you run a 275/35 in the rear it looks like a stupid 4 wheeler imo, but you get more sidewall flex with the 35 setup...
-Sean
Old Jun 20, 2007 | 07:11 PM
lowrider's Avatar
+1. A voice if reason in a sea of (oh, nevermind). With the proper offset 275/35/19 wont ever rub.
Lou
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
cmesidewayz
Sep 29, 2015 09:28 PM
n2fooz
Sep 4, 2015 07:46 PM
