Stern 20" offset question
Old Jul 6, 2007 | 07:17 PM
TGMcCoy's Avatar
I made a typo, but i figure the result is the same. He said +35 all the way around not +38. He said he can get the +48 if I wanted them, so that's what i'll do.
Old Jul 6, 2007 | 07:18 PM
perry05G35's Avatar
^ the stern site lists the +48 as an offset for that particular series of wheel (touring) but it does not specify the ST1 as being available in +48 on 20X9.5 but from what I recalled the seller on eBay did not have the ST1 in a +48 just +38...
Old Jul 6, 2007 | 07:20 PM
TGMcCoy's Avatar
Originally Posted by Socal_G_sedan
Does the ST-1 come in +48? I was told they only make up to +38
I can't give you alink to the exact spot on the site, but if you click on the all design style in the stern section you'll see the st-1s and it shows all the offsets available for that rim.
http://www.sternwheels.com/
Old Jul 6, 2007 | 07:51 PM
ttrank's Avatar
Grocery getter
Here is a +47 rear 9.5".
Old Jul 6, 2007 | 07:52 PM
TGMcCoy's Avatar
Socal, you said you had +38 all around, and it's cutting it close, but it fits. Does the +38 give more of a lip than the +35? I want the best fit with the biggest lip
Old Jul 6, 2007 | 07:54 PM
TGMcCoy's Avatar
looks good ttrank, did you have to roll your fenders for that to fit? Also, what was your offset on your fronts when you had those rims(i know you're running 20x10's in the back these days)?
Old Jul 6, 2007 | 08:09 PM
ttrank's Avatar
Grocery getter
Those are the volks that are on my car right now (and for sale in the marketplace ). Those are 8.5" +39F and 9.5" +47 R.
Old Jul 6, 2007 | 08:22 PM
TGMcCoy's Avatar
Could've sworn you where running 10s in the back, maybe some previous rims you had...
I looked closer at the stern site and see now that the +35 are only offered in 5x112 bolt pattern, so I guess i'll have to go with +38, which should be fine, right?
Old Jul 6, 2007 | 09:57 PM
G SEDAN's Avatar
that question has been answered already in my previous post, take a look at my 8.5 with +38 offset, you tell me if it will fit if it was 9.5 and size 265 width tires
Old Jul 6, 2007 | 10:12 PM
(>")> G35's Avatar
a +38 on 9.5" in the rear is doable, but it will rub for sure and stick out on a stock suspension. Take a look at the ST-5, it has rears that will work:
https://g35driver.com/gallery/browse...mageuser=43879
Old Jul 6, 2007 | 10:46 PM
mforrest100's Avatar
OK. I was going to wait to ask this question but I would like to take this thread a step further. I am looking into getting a set of 20" DPE's and I recently purchased a Rotora 14" (355 mm) Front and Rear BBK. I want to go staggered with the DPE's but I have no clue what offset can get me 8.5 (Front) and 9.5 (Rear) and still allow room for these brakes. Please let me know your thoughts and opinions.
Thanks,
Mike
Old Jul 6, 2007 | 11:46 PM
(>")> G35's Avatar
^your going to need to let DPE know about your BBK and it'll be up to them to see if they fit. Clearing calipers really has to do with the spoken design and very little with offset.
Old Jul 6, 2007 | 11:53 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Thanks,
Mike
are you doing all of this on a sedan?!?! cant wait to see it! like previously stated, once you tell DPE that you need BBK fitment they'll get you offset's and pads for the wheels that will fit over the BBK. and they most likely will NOT give you the offsets of the wheels.
-GP-
Old Jul 7, 2007 | 02:43 AM
TGMcCoy's Avatar
my bad man. You are correct, it was answered.. by you . So im goin with +38 up front and +48 for rear. Those look nice on your car btw, did you drop your car, and with what? coilovers, springs?
Old Jul 7, 2007 | 03:08 AM
  #30
G SEDAN's Avatar
G35 sport suspension with unrevised Z springs
