Wheel Spacers revisit
Old Jul 8, 2007 | 06:31 PM
ojman's Avatar
Hi Guys,
I am looking at a set of M45 wheels with stock M45 Potenzas for my 2005 G35 Sedan and am concerned about using spacers. What do I need to replicae the stock offset and avoid any rubbing and what are the safety concerns if any? Which are the best spacers to buy?
Thanks
Old Jul 8, 2007 | 08:14 PM
ttrank's Avatar
Grocery getter
If I remember, 10-15mm is a good choice. H&R makes nice spacers but there are others. Just make sure to get the longer wheel studs with them.
Old Jul 9, 2007 | 09:30 PM
GTR_G35's Avatar
I used 5mm eibach spacers on my M45 wheels. I would use the 10mm if I had to do it again.
Old Jul 9, 2007 | 10:09 PM
perry05G35's Avatar
5mm sounds too small for the M45s do you have pixs of what that looks like mounted?
Old Jul 10, 2007 | 12:58 AM
FlyingLumpia's Avatar
I think vq hotness ran 5 but what i remember he said would have ran 10 if he did it all over again.
Old Jul 10, 2007 | 01:13 AM
(>")> G35's Avatar
5mmwill clear the brakes, however it will look tucked. I'd go 15mm for a flush look and you can get the spacers with the lugs in them, so it's easier to install.
Old Jul 10, 2007 | 01:51 AM
DenverG35X's Avatar
I've got 10mm spacers on my M45 sport wheels.
Old Jul 10, 2007 | 09:59 AM
dunglan7's Avatar
I've got 5mm spacer up front with the stock stubs. No problems so far.
Oh, I got H&R!
Old Jul 10, 2007 | 07:29 PM
ojman's Avatar
How about the safety concerns of using spacers?
Old Jul 10, 2007 | 09:00 PM
VQ Hotness's Avatar
Oh, I got H&R!
Bad idea.. I did the same thing and im lucky i didnt kill my self.. Get studs fast!.
Wow their are alot of M45ers out their! Glad i changed it up.
Old Jul 10, 2007 | 09:05 PM
VQ Hotness's Avatar
Yea most of the newer spacers that come with studs in them come with a conical bolt that will need a 4 prong tool to attach to your studs on your hub. Make sure the spacers come with this tool b/c i could not find a shop that had the tool. But i made a quick call to seller and he shiped it out free of charge in my case.
Old Jul 11, 2007 | 09:45 AM
dunglan7's Avatar
What happened?
Old Sep 23, 2007 | 07:27 PM
ashish's Avatar
Do you guys think i would have rubbing problems on the fender if i did 15mm all the way around? i'm trying to decide between 10mm or 15mm
Currently have a z springs in the front and coupe in the back.
Old Dec 23, 2007 | 10:50 PM
07 G35S Sedan's Avatar
Oh, I got H&R!
Are you still running the 5mm spacers with the factory length studs? If so any problems? Is it safe?
Old Dec 23, 2007 | 11:06 PM
ashish's Avatar
Would not recommend using 5mm without the extended studs.
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
