tire size help
tire size help
Im currently running 19x9s in the front and 19x10s in the rear and the current tire setup is 245/35 and 275/30 on an 04 coupe. I have to replace these tires and I wanted to put more meat on the rear to give it more protection (there are big potholes everywhere). Would 275/40 be too much? Would it throw off my vdc or anything?
255/35-19 front and 285/35-19 rear give you the proper overall diameter.
You should not be at 275/30-19 rear by any means.
You can go 245/35-19 front and 275/35-19 rear. A 40 series would be too tall and would probably rub.
Question:
The stock 19s are
19x8 225/40/19 (front)
19.x8.5 245/40/19 (rear)
so how come if you're running 19x9, or 19x10, you can't use 40 profile? Is it because the tires are too wide and you'll rub? How come most people running 19x9 or 10 use 35 profile tires?
I'm also worried about pothole protection...
The stock 19s are
Originally Posted by jig8
Question:
The stock 19s are
The stock 19s are
gotcha, so you're saying that 19x8 225/40/19 will have the same side wall height as 19x10 275/35/19?
thanks, i'm learning new stuff err day!
