Almost got killed
Old Aug 5, 2007 | 02:05 AM
ekwc's Avatar
Almost got killed
It was raining lightly in the Monday morning at Boston, and I was driving to work as usual on the highway 93. My car (G35x) was going straight at about 60 mph on the most left lane.
It suddenly slipped to the right and almost hit a van and car on the other lanes. I was trying to brake and the ABS was going crazy to keep the car from loosing control.
My car finally stopped and the front of my car was facing to the opposite direction of the road. I was seeing the cars coming toward me, so I did a 3-point-turn on the highway and kept going as fast as the car could handle at that time. Then, I asked myself, "Am I still alive?"
Few days later, I checked my tires and the shoulder of my front tires are totally worn out. I also see my rear tires are cracking around the sides. They are OEM “EAGLE RS-A” and have about 30K on them. I didn't expect my tires would be gone so fast. So, check your tires before it is "too late".
Old Aug 5, 2007 | 09:25 AM
jaysan's Avatar
did you drive over a puddle on one side of your car?
Old Aug 7, 2007 | 10:44 AM
Q45tech's Avatar
"OEM “EAGLE RS-A” and have about 30K on them. I didn't expect my tires would be gone so fast"
Frictionwise most tires are significantly different after just 8,000 miles due to heat cycling of compounds.
If as new performance is desired the tires must be as new or at least not half worn! Tread depth is an iffy indicator! A Shore Durometer will tell you how much your tires have degraded!
http://en.wikipedia.org/wiki/Durometer
Old Aug 7, 2007 | 07:07 PM
ekwc's Avatar
No puddle. It might have some oil on the road, I guess...
We need to start a group buy for one of those Shore Durometers
Texasscout
Jul 24, 2015 03:43 PM
