For those of you with 20" Rims
Originally Posted by Red_G35
safe to do 285s on a 10" wide rim?
Originally Posted by terrycs
You also have to consider how the weight is distributed on the rotating assembly. The further out the weight is to the OD (assuming they are all the same for speedometer accuracy), the more power it will take to start rotating the wheel/tire assembly. The car will theoretically accelerate slower as you go up in wheel diameter. Will you feel it? Maybe, or maybe not; but aren't + size wheels for the bling? If so will it really matter much?
IMO, unless you are autocrossing, go with what looks good to you.
BTW ... you can easily chop more rotating mass by going to a BBK!
Originally Posted by DHCrocks
yes I'm running a 285/30/20 on a 10" wheel. the fit is pretty good, there's a little bulge in the sidewall to protect the wheel from curbing. the specs for my tires are 9.5" to 10.5" wheel for safe mounting so 10" is right in the middle.
Originally Posted by tiguy99
Yeah...I want to check these out too. See what their designs look like. I've been hearing so many nice things about them.
Big brake kits usually utilize aluminum hats with 2 piece rotors vs one piece all steel rotor/hat combination. This allows for lighter rotating mass and unsprung weight.
This is a very expensive upgrade just to save some weight.
Damn that's alot! Other than increasing stopping power over stock, how much weight reduction are we talking here?
Would it be worth the 2500 or 5000 (assuming we're looking at both front and back) just to reduce the weight the extra wheel size produces?
They'll have data for the 2007 G35 shortly.
DH how would you rate the acceleration/braking ride and drive performance with the current setup you have now vs how it was stock?
And what were some of the major differences you noticed when you first drove with this setup vs how it was before? Can I ask you one more question....how is your gas mileage compared to stock like did it drop, did it go up or stay about the same?
braking is noticeably less too, it takes more effort to slow the car down.
ride it a little bit more rough, you can really feel every little pebble in the road but it seems to take pot holes in stride.
gas mileage went down maybe 0.5mpg.
all in all performance, ride and economy were sacrificed for looks.
#30
acceleration is a little slower, it's very noticeable right off the bat but you'll get used to it. I didn't time it or anything but I'd say it's about equivalent to when I put on my test pipes (straight pipe instead of catalic converters) must be around 10hp or so.
I have 20x10 DPE GT7 with 285/30/20 BFG KDWT. here's a pic of how the tire fits on the wheel.
i would assume these are the forged wheels people have been raving about as far as being light etc? Do you know their weight off hand the website doesn't have it listed.
BTW Tirerack has your 285/30 BFG tires weighing around 31 lbs a piece. Don't know if it helps but just wanted to put that out there
