Too aggressive?
Old Aug 15, 2007 | 02:26 PM
G35Asian's Avatar
Too aggressive?
I'm planning on picking up a set of 19s with a pretty aggressive offset. I have a G coupe and my rear fenders are rolled in preparation. The wheels I'm looking at have specs as follows:
Front 19x9.5 +15
Rear 19x10.5 +15
Are these wheels too aggressive for a G? They are coming off of a Z and look awesome. I have seen some G owners run 19x9.5 +17 F & 19.10.5 +18 R, didn't know if the few extra mm's would make that big of a difference. Thanks in advance for the input.
Julian
Old Aug 15, 2007 | 02:40 PM
superdds's Avatar
depends on the which tires you plan on running, how low your car is and how much negative camber you plan on running.
Old Aug 15, 2007 | 03:09 PM
G35Asian's Avatar
I am currently running Tanabe DF210 springs for my drop (1.8f, 1.6r) and will be running 275/30's in the rear and 245/35's in the front. My camber is at -2.4 degrees right now.
Old Aug 15, 2007 | 03:15 PM
dream_G35's Avatar
pics of the wheels! and yes it should look good
Old Aug 15, 2007 | 03:24 PM
Vinny@VTR's Avatar
these ahve to be the JP Scaras for sale... either way, they'll fit wit a little more camber than the usual, but also you'll need to roll that rear real good!
Old Aug 15, 2007 | 06:16 PM
G35Asian's Avatar
Yeah, they should definitely look good
Old Aug 15, 2007 | 06:26 PM
redlude97's Avatar
they'll fit fine, the G has a few mm of extra clearance than the 350z, so if it fit on a Z, then it will fit on a G
Old Aug 15, 2007 | 06:33 PM
G35Asian's Avatar
Oh yeah?! I always thought that Z's had a little more fender clearance than a G. News to me!
Thanks,
Julian
Old Aug 15, 2007 | 06:46 PM
nghiars's Avatar
Thanks,
Julian
it just looks that way
imalazeeass's Avatar
pretty sure they are not JPs.. what rim are u talking about OP??
Old Aug 15, 2007 | 07:00 PM
Calvin's Avatar
Overglorified Altima
stick with 275/35...roll your fenders and have some aggressive camber...you'll be fine.
lots of people run +17 on a 10.5" rear...2mm isn't much of a difference.
Old Aug 15, 2007 | 07:05 PM
redlude97's Avatar
Lots of people run +17 10.5 with 275/35/19 and don't roll their fenders, so with a fender roll, I think +10 should be easily doable, +15 is nothing
Old Aug 15, 2007 | 07:13 PM
Calvin's Avatar
but most members with a 275/35 & 10.5 wheel aren't dropped on df210s!
if he rolls the fenders, then he can get away with a more positive camber.
Old Aug 15, 2007 | 07:34 PM
G35Asian's Avatar
True . The Tanabes are a low drop! I was looking into some coilovers also to help out. Anybody have pics of the fender clearance of a 10.5" wide wheel with a +17 offset?
Old Aug 15, 2007 | 07:37 PM
superdds's Avatar
you most definitely need to roll your fenders if you're running +17 in the rear. i was only dropped on htechs with +18 gt-s and i rubbed whenever i hit a dip...this was before the roll.
