Question about 20 inch rims on a lowered G35 Sedan
Old Aug 16, 2007 | 06:42 PM
05BlkG35Man's Avatar
Hello,
I have a question. I just lowered my sedan with the eibach sportline springs 1.6 Front and Rear. Will the 20 inch rims still fit on my vehicle? and what else would I need to do to make it fit i.e. roll the fenders, what size tires to run staggered and offset? I plan on getting Sevas S7s which have a +40 offset.
Thank You
Old Aug 16, 2007 | 06:46 PM
ttrank's Avatar
Grocery getter
That is going to be very low and your fronts might rub. Since the eibach 1.1/1.1 kit drops you to just above the top of the tire on 20's you are going to be LOW.
If you got the 10" +40 rears you are going to have to roll your fenders. Tire size 245/35/20 and 275/30/20. Other than that, good luck!
Old Aug 16, 2007 | 07:21 PM
So am I going to have to roll the front also. I already know possible I will have to roll the back if I plan on having people sitting in the backseat.
Old Aug 16, 2007 | 10:41 PM
Capthook's Avatar
I am pretty sure the fronts are already roll in, right?
Old Aug 17, 2007 | 12:02 AM
ttrank's Avatar
Grocery getter
Right, the fronts can't be rolled much more.
Your problem is more that you are going to hit the fender liner and inner fender. I would go with the pro kit.
Old Aug 17, 2007 | 12:40 AM
gsRt5's Avatar
Im on Tein S tech, which I believe is lower than the Eibachs and I have no rubbing in the front...I did roll the rears but it still looks like I have a bit of room. I dont even rub with the back filled with 3 ppl...
Old Aug 17, 2007 | 01:51 AM
UPandCOMING.G35's Avatar
^^^ Same with me but i do rub occasionally in the rear with 3 ppl in the back and my big sub too. but only on speed bumps. And yes the S-Techs are lower than the Eibachs.
Old Aug 17, 2007 | 03:12 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
you shouldnt have any problems with rubbing. I slammed my sedan on Tein Basics (about a 3" drop up front) with the S7's and only had rubbing going up driveways. Other than that, like Tim said, roll your rear fenders and run 245/35F 275/30R and you'll be all set.
-GP-
Old Aug 17, 2007 | 09:34 AM
digital1986's Avatar
what springs would I use to to get a minimum drop in the back and a decent drop in the front
(no thread steal)
Jusseth
Sep 13, 2020 12:25 PM
rezendvous420
May 31, 2020 01:26 PM
laksjd84
Jul 24, 2015 05:12 PM
Kal Hamm
Jul 24, 2015 08:55 AM
EasySausage
Jul 14, 2015 11:17 PM
