damn another 700 hundred dollars
Old Sep 1, 2007 | 03:20 PM
fabulustt7's Avatar
well these tires are brand new just got them on wed....do you mean spray my wheel with soapy water???or tire???
Old Sep 1, 2007 | 04:24 PM
G35 Mass's Avatar
BOTH! If you're still loosing air pressure like that, it's most likely the wheel is the problem. Are these two-piece wheels? Maybe they're leaking where they went together. As some other people states, there could be a problem with the bead or the stem. Spray it down and check it out....
Old Sep 1, 2007 | 05:04 PM
redlude97's Avatar
If they were 2 piece, the barrel couldn't possibly be leaking where it attaches to the center piece, its solid. If it were a nonwelded 3 piece wheel, then it could possibly be leaking from the seam
Old Sep 2, 2007 | 03:07 PM
fabulustt7's Avatar
it is a 3 piece rim...maya mrs.not sure if its welded or not but i think it is coming from the rim. its weird though it only leaks overnight. im going to take it to this wheel place in brooklyn that fixes bent rims, hopefully they no what the problem is. last night when it was leaking air i could hear it. it was coming from where the stem is but i think the bend in the rim is on the inner side of the rim right by the stem im not sure
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
JoeMac
Sep 28, 2015 12:28 AM
