request most aggressive offset on 8.5/10
Old Sep 14, 2007 | 02:30 PM
kenasaki's Avatar
Originally Posted by ttrank
Just do it now...
I need more people in debt like me.
lol..did u add me to your list yet?
Old Sep 14, 2007 | 02:40 PM
ttrank's Avatar
Grocery getter
I will now!
Let me know when you hit the $10k then $20k then $30k marks!
Old Sep 17, 2007 | 10:27 AM
terrycs's Avatar
Just curious .. has anyone gone wider than 8.5" on the front of a sedan? Been looking without much luck. Thanks.
Old Sep 17, 2007 | 01:22 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
I've got a 9" wheel on the front of mine. The offest is +30 with a 225/45/18 so its stretched to fit right with the fender. If you want to run a conservative offset and still fit a 245 tire then get a +40 or higher.
-GP-
Old Sep 17, 2007 | 01:49 PM
terrycs's Avatar
I guess I should have asked what the widest tire is as well. People have been using 245 on 8.5" on the 07 (no doubt based on the fit of the legacy sedan). I'm starting to think 255 on 9" for an 07 .
-GP-
Old Sep 17, 2007 | 02:28 PM
NorthSideRacing's Avatar
I'm going to be going with an 8.5/9.5 +25 all around setup when i order my wheels. I'll be running a 235/35/19 front and 255/35/20 rear with -2.0 camber all around.
You can go very aggressive if you're willing to deal with increased tire wear from negative camber and if you buy a front and rear camber kit to dial in camber.
-GP-
o snaps! thats going to look sick!
Old Sep 17, 2007 | 06:49 PM
ttrank's Avatar
Grocery getter
It is possible with a high enough offset but you are going to be very close to the suspension. I was going to try it with my iForged but they don't make the 2-pc reverse lip in a 20x9 so I went with the good old safe 8.5.
Old Sep 17, 2007 | 06:50 PM
ttrank's Avatar
Grocery getter
As for the rears, here is what a 20x10 +42 looks like. I think this is the perfect rear offset for the sedan. This is with only -0.5 rear camber so you could go a bit lower offset if you had more camber. Check out that fresh wax job.
Old Sep 21, 2007 | 12:25 AM
jedmonds's Avatar
Will a 35 offset on the front with an 19x8.5 inch wheel and 245/35/19 tire rub on the fronts???
Old Sep 21, 2007 | 12:44 PM
ttrank's Avatar
Grocery getter
Should fit fine.
Old Sep 25, 2007 | 12:44 AM
GS3's Avatar
GS3
also think it should be fine...
another month or so i hope to post what is in the making.. 20x8.5 +30/20x10 +37..
Old Sep 25, 2007 | 02:19 AM
ttrank's Avatar
Grocery getter
/20x10 +37..
What kind of rear camber are you looking at with that?
Old Sep 25, 2007 | 02:26 AM
Depends on the tire size and brand of tire. You could fit that in with a 275 and -1.5 camber with rolled fenders. The 8.5 +30 should fit no problem, even with a 245, if the car isnt slammed.
-GP-
Old Sep 25, 2007 | 02:28 AM
That looks perfect Tim! That's about how my +25 is going to look with a 255/35 and -2.0 camber.
-GP-
Picture Share
Feb 4, 2018 12:41 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
TurTLe*
Sep 29, 2015 01:43 PM
