Project Kics Wheel Spacers Vs. Others
Old Sep 24, 2007 | 08:48 PM
Strtsk8r321's Avatar
Is there any difference between project kics hubcentric spacers and other brands like H&R and Ichiba?
I am planning on getting 20mm in front and 25mm in back for my oem 19" wheels. Anyone done this without fender rolling?
Old Sep 24, 2007 | 08:52 PM
redlude97's Avatar
The kics bolt over the stock studs in the 20mm size, while the H&R and ichiba have replacement studs and built in hubcentric rings. The kics uses a seperate hubcentric ring. Eibach is another brand to consider, they make both types of wheel spacer and are hubcentric
Old Sep 25, 2007 | 10:06 PM
Thanks^
Old Sep 25, 2007 | 10:28 PM
fbw5595's Avatar
Replacing the bolts can get pricey, but I would guess that it is stronger (race ready) this way.
Old Sep 26, 2007 | 10:59 AM
waijai's Avatar
i.love.gold
I'm very hapy with my H&R spacers, which did include longer wheel studs.
Old Sep 27, 2007 | 06:57 PM
sugsss's Avatar
just got my h&r spacers and the studs are built in like the kic's spacers is this a new version? spacers are 25mm all around.
Old Sep 27, 2007 | 08:29 PM
BayAreaRefuGz's Avatar
i fly low
srry for hi-jacking, would ichiba 25mm (rear) clear fender with g35 s-tech drop?
Old Sep 27, 2007 | 09:49 PM
^ I wanna do the same thing with oem 19s. Will it clear?
Old Sep 27, 2007 | 10:25 PM
i fly low
i just got done installing mine. i have an 06 coupe with OEM 19s with g35 s-tech and it will clear
-jeff
Old Oct 1, 2007 | 01:38 AM
does lowering it make the gap bigger or smaller?
Old Oct 1, 2007 | 08:48 PM
Beebo's Avatar
sorry to thread jack but where can i buy H&R spacers 20mm in front and 25mm rear for my stock 19's
Old Oct 2, 2007 | 09:42 AM
Beebo's Avatar
Bump
Old Jan 3, 2008 | 10:12 AM
SLVRBullet22's Avatar
I just got some Project Kics spacers & wanted to know if there was a DIY walkthrough for it on the site. Anyone know?
Thanks,
CJ
Old Jan 3, 2008 | 07:05 PM
tjlazer's Avatar
The reason there is no DIY is becuase it is easier than eating a piece of cake... LOL
Just remove that bolt on the front rotors as it is there so you dont put the rear wheels on the front. Thats the most asked n00b question there is, other than that it's cake. Just make sure and tighten them down enough, but not too much or you may break the lug tool that comes with them.
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
Albanian122
Aug 1, 2015 08:41 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
