+35 offset for 19s sound right?
Old Sep 27, 2007 | 06:03 PM
G-MENTED's Avatar
i found out that the rims i want in 19s come with a +35 offset for both front and rear. i was recommended to get 20s with a +20 front and +25 rear offset to get it perfect, but since im gettin 19s.. +35 all around is what is only available for a g35 coupe. will this clear brembos and stay flushed?
also, im gettin 245 35 19 front and 275 35 19 rear sizes for tires. i didnt realize 275 35 19 tires were that unique. most shops dont have it and it costs more to get that size.
Old Sep 28, 2007 | 01:30 PM
G-MENTED's Avatar
Old Sep 28, 2007 | 01:36 PM
Gilley's Avatar
+35 on all corners is a good sedan offset, but not for coupes.
Offset is connected with the width of the rim. An 8 inch wide rim with a +29 offset will be different than a 10.5 inch rim with a +25 offset.
My 20's are 20x9 +26 and 20x10.5 +29.
Play with this calculator to see the relationship between the two.
http://www.rims-n-tires.com/rt_specs.jsp
Old Sep 28, 2007 | 07:43 PM
G-MENTED's Avatar
yeah..
for 20s, they recommended a +20 for the front and +25 for the rear
im getting 19s... 19x8.5 front and 19x9.5 rear. im just makin sure i wont regret those damn +35 offsets. thats the only offsets they make in those rims for the G35 coupe.
Old Sep 28, 2007 | 08:08 PM
wayneside's Avatar
+35...you will probably regret on a coupe. like gilley said...that offset is more for a sedan. what wheels are they?
Old Sep 29, 2007 | 01:29 AM
Gilley's Avatar
It doesn't make a difference whether they are 19 or 20. After you put the correct size tires on them, the outside diameter of the tires will be the same as OEM, but just wider.
Old Oct 1, 2007 | 12:36 PM
G-MENTED's Avatar
MRR GT1s
Old Oct 2, 2007 | 03:26 PM
G-MENTED's Avatar
i guess i probably shouldnt even get those rims. +35 all around seems like a bad idea...???
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
dcsbh1
Oct 1, 2015 03:15 PM
TurTLe*
Sep 29, 2015 01:43 PM
