When to rotate aftermarket tires - Michelin Ps2
Old Oct 13, 2007 | 03:50 AM
clinthammer's Avatar
I have 19" Michelin Ps2's 245/40/19 all around on work vsxx 19 x 8.5 +42 (with 5mm spacer making it +37). I put them on approx at 26900kms (16714miles).
I am currently at 32900kms (20443miles) and (touch wood) no problems with the tires.
Approx when should I get the dealer to rotate them?
Thanks,
Clint
Old Oct 13, 2007 | 08:47 AM
Q45tech's Avatar
Usually no point in equalizing [rotating] more frequently than every oil change 3,750 miles or 90 days.
Alot depends on how much your camber exceeds tire design points of -0.5 degrees static and what the actual camber is at speed and % of turning vs straight ahead miles.
I usually use sensitive finger tips to feel directional feathering saw tooth wear.
Old Oct 13, 2007 | 03:51 PM
HiTechOilCo's Avatar
Thanks,
Clint
Hi Clint. Especially with a front wheel drive vehicle, it is a wise idea to rotate and also rebalance the tires every 6,000 miles or 6 months, whichever comes first. Doing this on schedule will help keep your tires wearing evenly, stay quiet and obtain maximum mileage from them. If you drive your car very hard, even more frequent rotation/rebalancing will be of benefit.
Steve - B.F. Goodrich T/A Certified Tire Specialist
Old Oct 13, 2007 | 04:04 PM
redlude97's Avatar
Except we don't have FWD cars
Old Oct 13, 2007 | 04:53 PM
As many people read these forums with all manner of cars,the reference was a general reference, not a specific one, meant to educate/help anyone reading the post with any kind of vehicle and not only the original poster.
Steve - B.F.Goodrich T/A Certified Tire Specialist
Old Oct 13, 2007 | 06:51 PM
thanks Steve. will keep that in mind
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Footballmania32
19 Inch
Aug 13, 2015 03:07 PM
bjo16
Aug 4, 2015 09:52 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
